Question about D-Link AirPlus DI-524 Wireless Router
Wireless bridging how do i configure wireless bridging (WDS) on a Huawei HG520s router
  • keithbottoml Jan 30, 2009
    as about as helpfull as a chocolate fire guard, read your own manual!!!!
  • RA2000 Apr 17, 2009
    I have the same problem - when you open up the web browser (http:\ and select WAN setting Mode = Bridge; one loses all internet connection!
    Toggling back to WAN Setting Mode = Router still does not bring back internet as all the configuration settings are lost and not restored if you toggle between Router/Bridge (so backup your settings first!)
    Calling TT was no good, they completely duck the issue.
    I have a Belkin F7230 which is prefectly capable of Wireless Bridging; but it needs the router to be set up as a bridge, but I can't see what settings to configure on the HG520b to enable WDS.
    Help anyone !?
  • 85 Answers
Read ur user guide carefully in it it will give u ip addres with that it open in web browser then u can configured it .............
Posted on Jan 26, 2009
Where is wds bridging in belkin f7d2301
There is no Wireless Distribution System (WDS) on this Belkin product as it is a SWITCH, not a router.
See the reply from Belkin here.
Belkin F7D2301 Airport Xtreme BS 4th gen client configuration
You would have to buy a router, connect it to a broadband service and put this switch on the LAN side to get Internet access or connect up to a Wireless device.
Dec 23, 2014 | Belkin Computers & Internet
Wireless repeating between DG834G (WDS configuration)
If you have two of the below mentioned routers and would like to extend wireless network using repeating feature between the two then you can perform the below steps to configure wireless repeating between them.
Configuration of Wireless repeating between DG series router (Capable of WDS feature) like DG834Gv3, v4, v5, DG834N, DGN2000, DGND3300
The below steps should be performed on both the routers so as configure same wireless settings:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with or
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Change the network name SSID to NETGEAR123. Select security options as 'WEP (Wired Equivalent Privacy)'.
6. Set the 'Authentication Type' as automatic.
7. Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Now perform the steps below on the first router say router A which connects to internet through ADSL line:
1. Click on Advanced Wireless Setting in the left hand side menu.
2. Check the option for Enable Wireless Bridging and Repeating
3. Select Repeater with Wireless Client Association and enter the MAC address of the router B.
4. Click Apply.
Now perform the same steps on router B and make sure to enter the MAC address of router A on step 3 above.
The above steps would help you with the configuration of wireless repeating feature between the two DG routers as mentioned initially. The only thing that you need to take care is that both the routers should be configured with same wireless settings.
on Mar 19, 2010 | NetGear DG834G Router
I cant access the 192,168,2,1
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is, then you would route through that, and set your Repeater (Extender) IP to so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: Hope i helped you.. great day to you.
Jan 30, 2013 | TENDA A3 150Mbps Wireless Range Extender
Router modem-CAT5 adaptor
does this router have a lan1 lan2 lan3 lan4 ports ?
the adsl port may be for a phone line so you may need to turn off the ADSL functions in the Huawei Echolife HG520s router . Turn off the DHCP server and then plug connect lan1 to your office network. Change the ip address to be unique in your office network ip network range.
maybe if office router is subnet mask made the same .
Jan 30, 2018 | Computers & Internet
WDS Setup
In a WDS network, all the access points need to be in WDS mode, and one of them needs to be wired directly to a routed internet connection.
Here is a very good detailed tutorial on how WDS works and how to configure and troubleshoot your own WDS network:
How To: Setting up WDS Bridging / Repeating
Jun 03, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
D-Link 2000AP+ and 2100AP Bridge configuration
Solution #1
Set the DWL2000AP+ as "Bridge Mode" and the new AP (DWL2100) in "WDS Mode".
On each device set the MAC address of the other device.
Solution #2
Set the DWL2100 as "WDS with AP Mode" and the DWL2000 in "Bridge Mode".
Aug 31, 2009 | D-Link : DWL-2100AP Wireless-G 108Mbps...
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect ds to wireless router - Huawei Echolife 520s
Ensure that the B type is enabled in your router and that the security it set to WEP and that your passcode is correct.
Oct 27, 2008 | Nintendo DS Lite Console
Hg520s Huawei wireless router
Make sure you LAN settings is looking at your Wireless Adapter for WAN source, your computer might be looking up to the Wired Adapter for source, with not much info that's all i can suggest.
Create a new connections and make sure Wireless Adapter is selected.
Hope this helps
Apr 27, 2008 | Computers & Internet
D-Link AirPlus DI-524 Wireless Router Logo
1,220 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
