Question about Kenmore Blenders
Kenmore blender leaking
Leaking around blades
  • 1214 Answers
SOURCE: KENMORE BLENDER
YOu should be able to go to the searspartsdirect.com website and find the exploded parts list and order the part.
Let me know if you have trouble or need any additional help.
Posted on Feb 03, 2009
lucgalman
  • 87 Answers
SOURCE: My kenmore blender stopped blending!!!
There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
Posted on Oct 06, 2009
Testimonial: "Thanks i just cant find where the sell the parts at but you really helped me!!!"
espressonist
  • 1711 Answers
SOURCE: We have an old Waring Futura 900 blender that
Yes their is a gasket. However try to tied the hole blade kit a litle harder since it might be loose, it might be also dirty you can loose it clean it and put it back.
Have a visual insections since the glass might be broken a litle bit also.
Good luck
Posted on Aug 17, 2010
SOURCE: My blender is leaking slightly
I am guessing you have a KSB52. If the leak is through the blade spindle then tightening won't help. The "wingnut" is tightened through use anyway. The most likely cause is a failed seal. The whole blade unit will need replacing, search Amazon for 9704291
Posted on May 07, 2011
  • 244 Answers
SOURCE: How do I fix or
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Posted on Jun 16, 2011
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Leaking from around the base of the jug
When you clean your blender there is a rubber washer in between the blades and where they sit and the glass. Try pushing the blade assembly through the bottom and locate the large washer. Peal it off carefully under warm water then either try to replace it or clean it carefully in soapy dish water. Let me know if this helps, OK?
Jud
Sep 20, 2010 | Russell Hobbs 3902US Work Top Blender
Hand blender bottom shaft (blade attachment) leaks oily stuff
In the old days, there was a packing in certain places of certain applications.
Often it looked like a piece of string, usually a grayish color, as it often was impregnated with grease.
I would start with an automotive parts house, but it must be old and have old folks to help you, as young ones have no such experience.
You could also try a plumber, they used some packing string.
As a matter of fact, I have some in my plumbing repair parts, though I've no used it in 30 years.
You might have to use this each time you use the machine.
It should be not expensive.
God bless your efforts.
Mar 26, 2017 | Kenmore Blenders
Oct 06, 2009 | Kenmore Blender Single-Speed Blender
Leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Apr 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Leaking blender
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Jan 27, 2009 | Blenders
Osterizer Blender
You can replace the Osterizer "Standard Blade Assembly" (which includes a new rubber gasket) without buying a new and expensive glass jar. See http://www.householdappliance.com/blenderparts.html or one of the other appliance repair parts websites. After 20 years of use, it's time for a new blade and bearing.
Feb 27, 2008 | Blenders
Blenders Logo
23 people viewed this question
Top Kenmore Blenders Experts
Gil Shultz
David Ellis Rhea
Sonal Khare
Sonal Khare
Are you a Kenmore Blender Expert? Answer questions, earn points and help others
