Question about Zanussi TC7114W Electric Dryer
Electric dryer blowing cold air
Why is my roper electric dryer blowing out cold air
  • 979 Answers
You either have a blown fuse, breaker, burned out element, wiring that has come loose. They all can be checked within 5 minutes. However, I believe it is in the thermal fuse which is located below the top of the dryer. You can access that pretty easy though. To check it, just bypass it and put the 2 wires together and see if it runs. The fuse is only 15 dollars or so. I am assuming you have an electric dryer.
Posted on Jan 26, 2009
  • cd79 Dec 17, 2010
    this happened to my Zanussi TC7114S and it was the Thermostat.
Doesn't spin but it heats and blows air
probably the belt snapped that spins the drum
Feb 01, 2012 | Roper RES7646KQ Electric Dryer
I have a roper changed heating element. Still blowing cool air. Sister didnt tell me it only comes on in cooldown cycle. Wats could this be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 17, 2011 | Roper Dryers
The dryer the cheapest electric dryer made by roper just blows cold air duc is clear filter is clean everything works should i start by checking the heating element or coil hunter19-46m gave me good...
well, may be the heating element: here is the website. maybe something else like the thermal fuse, Good Luck Tim:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Apr 17, 2011 | Dryers
The dryer blows cold air instead of hot air.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 11, 2010 | Roper RGX4634KQ Gas Dryer
My Roper Electric Dryer is not blowing hot air plus the timer is not moving. What could be causing this?
timer motor(wires burnt or contacts) located in the upper back of dryer. here is a website that tells how to test, it is on the bottom of the list. Good luck Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 27, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer suddenly is just blowing cold air
heatman101
Sep 06, 2010 | Dryers
Roper electric dryer keeps blowing thermal fuse. motor will not run when this happens.it is bypassed for the time being,but want it fixed immediately. Did clean completely dryer lint trap and air duct to...
Remove the lint chute and give that a good cleaning wash it and the filter out1f161fc.jpgCheck and see if the element is shorted to the frame. That will blow the fuse too.
Sep 03, 2010 | Roper Dryers
Zanussi TC7114W Electric Dryer Logo
922 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
