Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Carpet shampooer I bought a used bissell powersteamer carpet shampooer model number 1692-1.I have no manual and I can't get shampooer to work.I don't know if I am doing everything right.If someone has a manual or any suggestions they would be a big help.
  • 4 more comments
  • andy f Nov 02, 2007
    unit will notdispense fluid. i know it is assembled correctly & iknow problem is between the bottom valve & the trigger. is the valve opp. hydraucoly? it seems to want to work ie. accepts pressure & will dispense with manual pressure. i borrowe this piece of junk so will not invest too much time on it
    any comments?
    andy f
  • Anonymous Nov 12, 2007
    steamer to wor bissel power steamer model 1693=W
  • lacysmom Dec 09, 2007
    I have a brand new Bissell Model 8806-3 that will not come on. I've looked on the Bissell site with no luck. I really don't won't to go through the difficulty of packing it all and returning it. Help!
  • Randycat Apr 01, 2008
    i dont have a manual and i need one.
  • Anonymous Mar 19, 2014
    will not spray out of the bottom but it will spray out of the tools
  • Anonymous Mar 30, 2014
    fuses as soon as switched on
  • 48 Answers
The valve inside the machine is to short , the trigger plunger is not fully pressing the valve down. try adding a small pad to the end of the handle plunger at the bottom of the handle
Posted on Nov 15, 2007
  • 432 Answers
I couldn't find the exact guide for your model but the two links below are the ones bissell told me to use. http://www.bissell.com/images/UserGuides/1694-8806_607.pdf http://www.bissell.com/images/UserGuides/1697_1205.pdf I hope this helps:)
Posted on Jul 15, 2007
I need a manual for model 1692-1 Bissell powersteamer
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell 1692 PowerSteamer Clearview User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 01, 2012 | Vacuums
I am using a bissell powersteamer powerbrush shampooer and don't have a manual to refer to. My question is if the antifoam solution cannot be mixed with the cleaner solution, then where do I put the...
Best to have the model number of the unit you have.
If you go to this URL: http://homeappliance.manualsonline.com/manuals/mfg/bissell/1622_series_220240v.html
you will be able to find your manual by entering the proper model number in the search area.
Hope this helps.
Oct 10, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Changing belt on bissell powersteamer clearview 1692
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 11, 2010 | Bissell 1692 PowerSteamer Upright Vacuum
I need Bissell POWERSTEAMER® PROHEAT instruction manual
heatman101
hdf
May 03, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Carpet cleaner not working properly will not send out the water
his is a very common problem with Bissell Carpet Shampooers...
Fortunately it has a very simple solution.
The problem is caused by blocked water jets ! and if your machine is still under the two year guarantee,Bissell will collect and repair very quickly free of charge !
Good Luck !
Call them on
0844 888 66 44 - Option 1 (UK Only) (Monday - Friday, 9am - 4pm)
Sep 03, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell model 1631 manual
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Aug 30, 2009 | Bissell 1631 PowerSteamer ProHeat Canister...
Replace bel
There are 6 screws on the hood, remove them. Unscrew the cap which holds the red x in place and remove. Gently pull up on the top housing and it will come off. Remove the 4 screws which are on the pump and slide the pump out, install belt and reinstall
Aug 25, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissel shampooer
yes there is a belt on the side that will need to be changed
Jan 13, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Power Pro Bissell cleaner
Try going a diferent direction. Burber carpet is extreamly hard to clean because the nap it causes vacuums to bounce and shampooers to catch. just try using a differnt angle to shampoo the carpet from.
Oct 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
No manual or instuctions- where do I add the soap
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618963&thid=839930
No manual or instructions - where do I add the soap
Posted by kauikeolani on July 27, 2008
Bissell PowerSteamer carpet cleaner
Model 1694 -W 06270205H
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the Bissell Factory website or factory cust serv phone # listed below and they will send you out a owner’s manual or instructions if you give the name of the Bissell and the Model # and you can either download the item or you can have them send out an owner’s manual from the factory. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 27, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
438 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
