Question about Electrolux Vacuums
I have an Electrolux Z2332 elite vacuum cleaner and it is not suctioning - would i have replaced the bag incorrectly?
My vacuum cleaner is not suctioning
reddevil6
  • 1673 Answers
SOURCE: My bissell vacuum cleaner has lost suction...
Sounds like either the hose or the inlet down by the brush roll is clogged.
Posted on Jan 09, 2008
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
  • 22 Answers
SOURCE: kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
Posted on Feb 10, 2009
  • 73 Answers
SOURCE: Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Posted on Aug 27, 2009
There are 4 Symbols, next to the suction dial, on the Electrolux Epic 6000 SR vacuum cleaner . . . what does each symbol refer to ? J P Mac D
the dials refer to types of dirt.The higher the dial the heavier the dirt.This is for the auto shut off when the bag is full.The best setting is in the middle.If you are vacuuming up fine dust suck in some Kleenex before this will coat the bag and prevent premature shu toff.
Apr 29, 2015 | Electrolux Vacuums
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Aerus Lux 7000: the full bag light keeps coming on but the bag is not full.
Electrolux uses a pressure differential control valve. This valve measures air before and after the bag. There is a orfice or small hole where the hose connects to the vacuum cleaner, and a orice at the back of the bag canister. As the bag fills up the suction pressure reduces at the hose connection and increases at back of the bag canister. When this happens the control valve has a diaphram that closes, which shuts the vacuum off and gives you a full bag light. There is a thin plastic flange that prevents an o ring on the control valve stem from coming off. The flange breaks, the o rings comes off the stem and the vacuum will shut down indicatiing bag full. The after market price is about 22.00. The valve is easy to replace if you are familiar on electrolux vacuums. When I replace these valves, I use epoxy two part plastic putty on the flange of the valve. It takes 2 days to cure, but the flange will not break.
Jun 25, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Since I replaced the bag in my Eureka Rally 2 (this was the first time) the suction has not been working well. Could you please tell me what I could have done incorrectly. Thankyou
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Mar 28, 2011 | Eureka Vacuums
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Sep 28, 2009 | Electrolux Vacuums
I have Electrolux canister vac. The suction end pops open everytime it loads up.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689886
Generic problem for all Vacuums
Posted by wmcox on Jun 20, 2008
I have Electrolux canister vac. The suction end pops open every time it loads up.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In the door there are vacuum lines that could be pinched or bent and are not letting air through to the bag, the system is designed that if the bag get to full or the air flow is restricted it will pop the door open and save the motor from burn out. This is repairable and nor to expensive and to check with the local vacuum cleaner dealer in your area or to call the Electrolux cust serv @ the factory for further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Vacuum shuts off
if you want to fix this problem gently pry up the air flow control knob and look down at the plastic hose connected below the control valve. insert a small screwdriver and push off the hose from the valve. this disconnects the bag full indicator but will let the vacuum operate normally at full vacuum. you will change the bag when suction gets low. this will save you at least $100 repair bill.
Dec 31, 2007 | Electrolux Lux 5500 Canister Vacuum
Vacuums Logo
80 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
