Question about Toastmaster 1148X FastBake Bread Maker
No user guide
I need to know how long to bake bread(s) for. Whole grain & regular, 11/2 - 2 lb loaves. I know how to set the size,etc. but not how long to program the bread for.
Thanks
Where can I get a manual for toastmaster breadbox 1148x
Posted on Mar 08, 2009
I just bought your breadmaker B2200 and i am looking for recipes for a basic white and whole wheat bread.The booklet does not have basic recipes. I am looking forward to baking bread for a long time to...
Basic White
1 1/3 cups lukewarm water
2 tablespoons powdered milk
1 1/2 teaspoons salt
1 tablespoon sugar
2 tablespoons butter or margarine
3 3/4 cups white flour
1 teaspoon yeast
1. Measure ingredients in the order listed into Baking Pan.
2. Insert Baking Pan securely into unit; close lid.
3. Select BASIC setting and 2.0 lb. loaf setting. Choose LIGHT or DARK crust setting.
4. Push Start button. There will be a 15-minute preheat delay before mixing begins.
5. The Complete Signal will sound when bread is done.
6. Using pot holders, remove Baking Pan from the unit and carefully turn bread out of Baking Pan. (Mixing paddle may remain in bread. Remove paddle when load if cool.)
7. Allow to cool before slicing.
Time 3:50 hours
100% Whole Wheat
1 1/2 cups lukewarm water
2 tablespoons powered milk
2 tablespoons honey
2 tablespoons molasses
3 3/4 cups whole wheat flour
1 3/4 teaspoons yeast
2. Insert Baking Pan security into unit; close lid.
3. Select GRAIN setting and 1.5lb. loaf setting.
4. Push Start button. There will be a 25-minute preheat delay before mixing begins.
Time: 4.10 hours
Feb 19, 2011 | Black & Decker Bread Machine
Keeading blades
I had the same problem. I find the loaves to be a much better size if I just use program setting 8 - Dough then put the dough in 2 regular bread pans or on cookie sheets (bagetts), let them have a second rising and finish them in the convection oven at 350 F for 21 minutes.
Nov 20, 2009 | Black & Decker B2300 Bread Machine
Need recipe for 1 lb whole wheat loaf
I have a very healthy recipe. Makes two loaves so you will have to divide in two.
13 oz. water (warm)
3 3/4 cup stone ground whole wheat flour
1/2 cup steel cut oats
2 T oil
2 T dry milk
2 T vital wheat gluten
3 T honey
1 1/2 t salt
1 T active dry yeast
When machine beeps add if desired:
1/2 cup golden flax seeds
1/4 cup unroasted sunflour seeds or sesame seeds (or both)
Put into machine and go. I usually set it on dough cycle and put into pans for second rise 50min in a warm, draft free area. Preheat oven to 400 place bread in oven after second rise, reduce heat to 375 and bake 30-35 min.
You can find both flour and gluten with Bob's Redmill products
enjoy,
Evelyn
Mar 17, 2009 | Black & Decker B2250 Bread Machine
Recipes don't turn out for me
i got this bread maker for x mas as well and had to make a few loaves before i figured it out... i made a loaf the other day and it worked out perfect.... for the basic sandwich bread i just used lukewarm water, 5 cups of flour, and 3/4 tsp of yeast and it turned out perfect.... hope this can help out....
Dec 30, 2008 | Black & Decker B2300 Bread Machine
I need a manuel for my bread maker chefmate hb-12w
Here's the instructions for Model HB-215. Source =>
http://www.globalgourmet.com/forum/index.php?topic=47.msg222
The post below this post says Chef Mate - Models HB12W, HB215 and CM725 only! So, it might be the same instructions.
Chefmate Bakery Oven Model HB-215
Modes:
  • Standard 1.5 lb normal crust: Bakes a 1.5 lb basic loaf of bread in 2 hrs 30 min.
  • Standard 1.5 lb dark crust: Bakes 5 min longer.
  • Standard 1 lb normal: Bakes a 1 lb basic loaf of bread in 2 hrs 20 min. No “dark” option.
  • French mode: Bakes a French loaf of bread (salty taste) in 3 hrs 40 min.
  • Sweet mode: Bakes a sweet flavor loaf which tastes like a butter roll in 3 hrs 40 min.
  • Doughmode: Use this mode for making dough for rolls, croissants, doughnuts,etc., which you want to bake in your conventional oven. Prepares doughin 1 hr 20 min.
Control Panel: (when pressing a controlbutton, be sure to hold it down until you hear a “Beeping” soundindicating contact has been made.
  • Display: Shows the time remaining until a mode is completed. Can also display timer setting or mode selected.
  • Select button: Push to select mode: Cycles through modes in following order:
    Normal 1.5lb -> Dark 1.5 lb -> 1 lb -> French -> Sweet -> Dough
  • Start button: Push to start processing the mode selected.
  • Stop button: (press for one second to take effect)
    Push to turn off power after baking is completed or to reset the mode or timer.
    If used after a mode is started, it will stop it.
  • Timer set buttons: Up arrow: advances timer setting 10 min each time pressed.
    Down arrow: sets timer setting back 10 min each time pressed.
Ingredient Information
  • Flour– Use flour that is marked “bread flour” or “better for bread”. (Thesewill usually be labeled as having more gluten than regular flour.)
  • Dry Skim Milk – This enhances the flavor and adds to the nutrition of the bread.
  • Butter – Butter adds a rich flavor to the bread and makes it soft.
  • DryYeast – Yeast is necessary for causing the dough to rise. Select readyto use yeast which needs no preliminary fermentation. Use only activedry yeast. Don’t use 50% faster dry yeast.
  • Sugar – Sugar speeds up the dough rising process, adds flavor, and makes the bread soft and the crust brown.
  • Salt – Salt controls the activity of the yeast and makes the dough firm.
  • Water– Gluten is formed when flour is mixed with water. This allows thedough to rise by retaining air. The amount of water and its temperatureare very important. Usually, the water temperature should be between 68F/20 C and 77 F/25 C. When the room temperature is over 82 F/ 26C, usecold water (about 41 F/5 C). When the room temperature is under 50 F/10C, use lukewarm water (about 100 F/38 C).
Operating Instructions
Baking a standard loaf of bread using Standard Mode.
Ingredients for 1 lb loaf for 1.5 lb loaf
Water 7 ½ ounces (210ml) 9 ½ ounces (270ml)
Bread Flour 2 1/3 cups 3 cups
Dry Skim Milk ½ tablespoon 1 tablespoon
Sugar 1 tablespoon 1 ½ tablespoons
Salt 1 teaspoon 1 ½ teaspoons
Butter 1 tablespoon 1 ½ tablespoons
Dry Yeast 1 ½ teaspoon 1 ¾ teaspoons
1. Open the lid and remove the bread case (hold both sides of handle and turn counterclockwise.
2. Position the kneading blade on the drive shaft. (remove any crumbs from drive shaft.)
3. Place ingredients into the bread case. Add ingredients in the following order:
Pour in the proper amount of water.
Add the flour, sugar, salt, butter, and dry skim milk – in that order.
Place the dry yeast on the center of the flour.
Note:When using the timer, make a hollow depression in the ***** of flourand pour the dry yeast into it. Do not let the yeast touch the water orthe dough may not rise properly.
4. Place the bread case into the body of the baker. Turn clockwise to lock
5. Close the lid.
6. Plug in to outlet. (after being plugged in the number “0 00” will flash in the display.
7. Setthe standard mode. Press the select button to set the mode to Normal,Dark, or 1 lb, depending on your preference and the amounts ofingredients used.
8. Start. Press the START button. The timereadout in the display will begin counting down the minutes from theamount of time required for the mode you have selected.
Steam may rise from the vent on the back of the lid during operation.
When baking is finished, the buzzer will sound three times and the display will read “0 00”
9. Removingthe bread case. When the buzzer stops, press the STOP button and openthe lid of the baker. ( The heater in the unit will keep operating tokeep the bread warm for a while after baking is complete. When removingthe bread case, always be sure to press the STOP button to turn off theheater.) Using the handle and oven mitts, remove the bread case. Thehandle and bread case will be very hot. Do not place the heated breadcase on the body of the baker, table cloth, or plastic surfaces.
10. Removing the bread from the bread case.
Usingoven mitts, turn the bread case upside down and gently shake it toremove the bread. The surface of the bread case is slippery, so be sureyou have a firm grip.
If the bread can not be easily removed, turn the drive shaft on the bottom in both directions so loosen the bread.
Place the bread on a wire rack or similar surface to cool.
Note: when baking is completed, remove the bread as soon as possible. If leftin the case for a long period of time, its surface will become stickyand the flavor will be lost. If the kneading blade comes out with thebread, use a plastic or wooden utensil to remove it. CAUTION: it willbe hot.
11. Remove the plug from the outlet.
Baking a French loaf of bread using the French mode
Follow the above instructions, except select French mode in step 7 and use the following ingredients in the order shown:
Water 9 ½ ounces (270ml)
Bread Flour 3 cups
Sugar 1 ½ teaspoons
Salt 1 ½ teaspoons
Butter 1 ½ tablespoons
Dry yeast 1 ¾ teaspoons
Baking a sweet flavor loaf of bread using the Sweet Mode
As above, but select Sweet Mode in step 7 and use the following ingredients in the order shown:
Water 7 ounces (200ml)
Egg (medium size) 1
All Purpose Flour ½ cup
Dry Skim Milk 2 tablespoons
Sugar 2 tablespoons
Salt 1 ½ teaspoons
Butter 3 tablespoons
Dry Yeast 1 ½ teaspoons
How to use the timer. (The timer function cannot be used with Sweet or Dough modes)
The timer extends the time from pressing START until the baking completes.
1. Place all ingredients into the unit and plug it in.
2. Select the desired mode
3. Press up arrow once. The normal time for that mode will be displayed: 2:30 for a standard loaf.
4. Keep pressing up arrow (or down arrow) until the desired time to completion is displayed.
5. Press the START button to start the delayed timing.
Preparing a dough for handmade bread using the Dough mode.
1. Follow steps 1 through 6 for standard loaf. Select Dough mode in step 7.
2. Press START to begin the dough making process. It will take 1 hr 20 min. The display will show the time remaining.
3. Thebuzzer will sound 3 times to let you know the dough is ready. Take itout and shape it as you wish for baking in a conventional oven.
4. Unplug from outlet.
Dec 30, 2008 | Kitchen Appliances - Others
Top of loaf sinks in
I am having the same problem, I have made 3 loaves of white, they all did not turn out, and I played with the recipe a bit to solve it, but I keep getting the same result!
Dec 16, 2008 | Oster 5838 ExpressBake Bread Maker
Dense, heavy loaves
Hi nanearl,
(A personal aside - my personal experience with home-baked bread is that it tends to be a heavier product - - but that may be because the recipe gets experimented with, and whole grain flours tend to be used rather than bakers flour.)
It sounds like something is stopping the yeast from acting (fermentation creates to CO2 bubbles that cause the bread to rise). Was the yeast you used all from the same batch? (sometimes they have bad days at the yeast factory, too). Can you watch when it runs through the cycle, and check for conditions _before_ the dough is supposed to rise? If it heats up much too quickly/soon, the heat can kill the yeast before it get to do it's job.
You might be able to get more product-specific assistance from Zojirushi.
I'd go to Zojirushi's Support page at (TinyURL'd for brevity)
http://tinyurl.com/3jmx4g
There's a Service & Support link at the top of the page - locations of service centers and the like.
You can also call Zojirushi Customer Service Department - -
800-733-6270, M-F, 8:00 a.m. to 5:00 p.m. PST.
Also here's a TinyURL for the manual download page, just so you have it.
http://tinyurl.com/z39gu
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Feb 16, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
B2300 rise time
For user's manual: Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Dec 19, 2007 | Black & Decker B2000 Bread Maker
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Toastmaster 1148X FastBake Bread Maker Logo
114 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
