Question about Fisher and Paykel DEGX1 Electric Dryer
Dryer won't heat
Fisher Paykel dryer only about 3 years old will not longer heat. All the buttons function or light up and the dryer will run for a correct time frame, but NO HEAT, none at all! Think it is the heating element, but don't have a clue where to begin looking for it or how easy it is to replace.
  • 3 more comments
  • chartguy Feb 12, 2009
    Less than a month after you, I'm having the identical problem. They dryer runs through its normal cycle, blowing air, but it is not heating. I use an aluminum vent pipe, so you can feel if the exhaust has any warmth. There's none, whatsoever. It's as if it's on the air dry cycle, but I've triple-checked that it is not on that cycle.
  • kristi2063 Feb 26, 2009
    I have the same problem at this time. I have to take off the front panel and reset a small circular breaker about 18 inches from the right side on the bottom of the drum. I currently have higher voltage to my dryer circuit than I should have. Over time this I beleive has weakened the breaker. So I need to replace it. Ken
  • ctsmum Mar 01, 2009
    I have the same problem. There is no front panel on my dryer. Have no heat. Everything else seems to work.
  • Big Show Mar 14, 2009
    The dryer operator entry panel accepts entries and the lights indicate the dryer is functioning normally.  The door latches shut and the dryer starts and runs like it is supposed to -- there just isn't any heat.
  • IllinoisWes Mar 23, 2009
    Kristi, levonduski, you ROCK! Aside from a cut on my thumb from the the sharp edges, everything went as you described. Thanks!!!
I have a F&P dryer DEGX1 about three years old , followed kristi's advice and it worked. There are two screws holding the information panel on, inside there is a schematic with instructions on how to put the dryer in diagnostic mode and how to take the front panel off. i reset the breaker located at the bottom of the front panel on the heating element box and put it back together and it worked.
My vent cover outside was frozen shut and this caused the breaker to blow saving the heater elements, am changing the vent cover to a different design to prevent this happening again
Posted on Mar 07, 2009
Coming back to this well oafter the fact, but I did get this problem fixed. As it turned out, the rotating lint screen on the left side of the drum had a hole in it, which allowed lint to get in and pack in around the heat sensor that is being the lint trap box. (the holes came from a pack of gum my teenage son left in his pocket...) I ended up replacing the lint screen with a new one, cleaned out the area around the sensor, and it has been working like a champ ever since. Much cheaper than replacing elements and breakers, that is for sure.
Posted on Jan 17, 2010
I had the same problem, it turn out to be the circuit breaker. Instead of putting out 220a it was only putting out 110, which was just enough to run everything but not dry. I put in new 220a breaker and it started to run like new.
Following Kristi2063's lead, I took the front panel off and hit the reset button, and miracle of miracles, the dryer is heating again. This is the third or fourth time it has happened with this machine, and the technician who comes out always says that the filter was blocked . . . even though I empty the filter faithfully.
Posted on Mar 01, 2009
  • 130 Answers
F&P products are really service friendly. Id say take the back panel off and the element should be there behind a shield.
Posted on Jan 26, 2009
Fisher Paykel Dryer Model DE08-US1. Dryer won't start. When pushing the start button, there is a "humm" from the electric motor - like it's trying to start. Very sudden problem. ...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 18, 2011 | Fisher and Paykel DEGX1 Electric Dryer
I have a fisher & Paykel electric dryer. D-DE62T27D that works but won't dry. Any solutions? Thanks Rick
Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Dryer heating elements come in various shapes and sizes. They are all strung with a coiled wire made of a nickel and a chrome alloy. This wire receives, but resists, a controlled electric current and as a result, the wire heats up. The heat produced is used to heat and dry the clothes in your dryer.
Once you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it.
Jul 12, 2011 | Fisher and Paykel DEGX1 Electric Dryer
The model of my Fisher Paykel dryer is DEIX2 and it runs but doesn't get hot. It's four years old. Would it be cheaper to replace than repair? Thanks.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 04, 2011 | Fisher and Paykel Dryers
My 4 year old dryer is not heating so I want to try the reset button as well as cleaning out the inside to see if that will take care of the problem before ordering a heating element which I cannot afford....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 10, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My fisher paykel dryer is 3 1/2 year old. It works fine on med and low heat. On high heat, it heats up too much and turns itself off
clean the dryer of lint inside and also the vent tube:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Nov 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Heats when unit is not on
Same thing just happened to my DEGX1. I took it apart and one of the heating elements had broken and fell to the bottom of the metal case. I think it was creating a short to ground and making it heat. I removed the broken element wires and attached them back best I could and did a test run with no problems. It is not heating when off now either. searspartsdirect.com had the elements for $67 so I ordered a set and will replace both of them (part #395583). My dryer is only 4 years old and 3 weeks ago the driver belt broke. Irritating they can't make them last any longer these days.
Jan 22, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer run but no heat
Try pushing the reset button located inside the dryer housing. (Remove top, then outer housing 'wrap around', reset button is behind the outer 'wrap around' metal in the front of the dryer.)
Jan 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Venting a dryer outside
What do you need to reverse?
I understand that the wall kit is to blow the heated air from the dryer to outside therefore not humidifying the laundry.
Are you trying to draw air into the dryer from outside or blow the air outside?
Sep 14, 2008 | Fisher and Paykel DE06 Electric Dryer
FISHER PAYKEL DRYER
there is a reset button located inside the front panel on the dryer. Try pushing it.
Jul 14, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
575 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
sonic boom...
sonic boom...
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
