I need a manual for a Intertherm model # MGH065AB
Model # MGH065AB
Manual for model C7BAM03648C-C
According to the web, the model C7BAM03648CC is a Westinghouse refrigeration unit. Are you sure you didn't get the number from the top portion?
C7BAM Cased Vertical Coil
• R410 refrigerant-non-ozone depleting
• All aluminum micro-channel coil eliminates formicary corrosion
• Piston metering for all 13 SEER matchups
• Field installed TXV accessory for 14 SEER matchups
Recent Intertherm furnaces have "M" or "CMF" numbers.
Either way, you will probably have to contact a local dealer because their website is useless.
Intertherm Gas Furnaces
Mar 19, 2015 | Intertherm 56000 Btu Gas Furnace
Intertherm model # S30A-048KA 4 TON & matching coleman evcon system need manual
go on the internet or go to a dealer handling these units. should be able to download the info.
Sep 18, 2013 | Intertherm Heating & Cooling
Looking for an operatios manual for intertherm downflow gas furnace model MGHA056
Here's the closest thing I could find. It's a technical manual that shows all of the specifications, parts and ratings for the furnace. Hope it helps you.
http://www.intertherm.net/Literature/712a.pdf
Mar 08, 2011 | Heating & Cooling
How do find the service manual for my Intertherm model # EIFH-017HA A/C and furnace unit and / or how do i lubricate the fan and motor?
Normally maximum fan motors self greased for lubrication. And some models have oil drooping hole on motor itself.
About your requirement of manuals, please try with :
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Dec 16, 2010 | Intertherm Heating & Cooling
Need a product manual for intertherm model p5rd-036k
http://www.nordyne.com/Literature/455a.pdf
and here ya go. check this web site for your manual.
Hope this is what you want.
Dec 26, 2009 | Intertherm P3RA-036K Air Conditioner
I need a wiring diagram for a intertherm model # e2eb-015,017
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
INSTRUCTION MANUAL /INTERTHERM FURNUES
usually a power surge will fry the transformer unless sometimes if your lucky the manuf. installed a fuse either in line or on the circuit board. 5 amp or 3 amp....any thing bigger wont protect your equipment.
Jan 09, 2009 | Intertherm P3RA-048K Air Conditioner
Wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Dec 21, 2008 | Heating & Cooling
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
