Question about JVC GR-SXM260E Camcorder
Camcorder stuck in E02 Safemode
I get a read out on the display: E02 Unit in Safe mode. Its says remove Battery and reinsert and it should clare but it does not. After that appeared the Tape compart will not stay shut are those problems related ?
  • Randystark83 Feb 25, 2008
    my jvc is on guard-mode and i keeps eating my video tapes!!!!
  • khantje Feb 27, 2009
    hey,
    my problom is that i can't play anything on my digital camera,
    always the same massage comes on disply.
    so what should i do?
Really bad tapes maxwell,tdk...good tapes, panasonic,jvc fuji, that could be the problem for these specific camcorders...good luck
Posted on Sep 04, 2007
Hey have the same problem with my camcorder too far the past 3yrs send it to jvc they said no problem found but as soon i got it back it work for one day them went back to safe mode.they said they could rplace the head mechanicalism for $350 which is roughly what paid for the camcorder.if gotyours fix let me now
Posted on Jul 18, 2007
SOURCE:
My camcorder is stuck in safe mode and I can't eject the tape.
Have you attempted to remove the battery and power from the camera? Usually when a camera is stuck in safe mode if you remove all power from the device and wait a while (I would say 15 minutes should do the trick) it will clear the safe mode and you should be off and running.
Jun 27, 2011 | RCA CC6373 Camcorder
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
Unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
E02 error
E02 indicates that the mode switch did not rotate into the next position after 6 seconds during unloading attempt. This problem can occur for several different reasons, but almost always requires mechanism repair and retiming, a real pro job. Good luck, magic seadog
May 22, 2007 | JVC GR-SXM250 Camcorder
Safe mode
Run a head cleaner and restore factory defaults by going to your menu and select reset settings.
Jan 15, 2007 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-SXM260E Camcorder Logo
329 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
