Question about Foxconn 865A01-PE-6EKRS Motherboard
Compaq Presario Desktop SR1710NX
Powers up (green power light on) but does not appear to boot up or at least acknowledge any monitors I plug into it.
All components are attached to the motherboard, could I have a bad motherboard?
  • 88 Answers
It;s probably just your onboard video that has gone bad. You can put a video card in the system, then make sure you disable the onboard video in your system bios at startup.
I hope this helps,
Thanks for using FixYa,
Posted on Jan 26, 2009
Presario sr1710nx what type memory has an excellent wizard for locating memory.
Computer memory upgrades for HP Compaq Presario SR1710NX Desktop PC...
Lists memory compatible with your machine.
Memory Type: DDR PC3200, DDR (non-ECC)
Maximum Memory: 4GB
Slots: 4icon_note.gif Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
I have also found that the memory occasionally is not recognized. To fix remove the ram and clean electrical contacts with a clean pencil eraser. (Rub the contacts to clean.) Then replace memory. (My machine failed to boot, cleaning the contacts fixed the problem.
Nov 16, 2011 | HP Compaq Presario SR2150NX PC Desktop
Pressing the power switch on my compaq presario turns nothing on ; no lights appear
first remove thecover and remove all the power connectors from the smps the hold the 24 pin poerconector and short the green and black wire and see wether the smps fan is working if working remove the memory from the memory slot and clean the surface and insert it into socket and see wether the couputer boots
Aug 31, 2011 | Compaq Presario S6000CL (DT072A) PC...
I have a Compaq Presario SR2010NX that will not boot. When I plug in the power cable, a green light blinks at the back of the tower on the power supply. I was given the desktop in mint condition, which...
your power supply is bad. the blinking light means there is a failed component in the power supply. replace the power supply and you will be good to go. around 60 dollars at any computer place. please rate me thank you.
Jan 04, 2011 | HP Compaq Presario SR2010NX PC Desktop
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
It had been quite a while since I turn on my compaq presario 7204APr. And when it turned it on, there is no image appear on my monitor screen. How can I fix it?
Desktop PCs have separate power buttons for the monitor and the desktop component.
1. Make sure both items are turned on.
2. Make sure the cable from the Computer to the monitor is connected securely.
3. Are there lights on the monitor? Are they Green?
If they are amber the connection is not solid or the Video Card is bad.
Are there lights on the desktop PC? Are they blinking? If so the PC is working and the video is not. Check the connections and monitor power.
4. When you turn on the PC do you hear noise? If yes, the PC is working.
Beeps will sound if the video, memory or keyboard is not working.
After you check these things, reply to let us know if it is working or not.
Sep 10, 2010 | Compaq Presario 7000Z PC Desktop
Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Feb 12, 2010 | HP Compaq Presario SR2010NX PC Desktop
Can't get computer to turn on (compaq presario 5000)
Either your Hard drive (hd) crashed or your hd cable or port is faulty. if your software is corrupt boot with a boot disk (assume you are using XP or Vista), press R on the blue options screen. you will be given a black dos prompt screen. Type in fixboot and type Y for an answer.
Oct 26, 2009 | Compaq Presario 5000 PC Desktop
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site and restart the computer .
Apr 15, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
No booting for compac presario
do you hear your power on self test beep? check your video card. the monitor has a light on it it should be green if its working. what color is it? check all of your video plugins. It sounds like its booting but without video who knows
Jan 02, 2008 | HP Compaq Presario V2000 Notebook
Foxconn 865A01-PE-6EKRS Motherboard Logo
239 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
