Question about Pool & Spa
Intermittent starting of hurlcon pumps
Sometimes pump when manually switched on will only have a buzzing sound, other times will operate as per timing clock
  • 373 Answers
SOURCE: 1993 Acura - intermittent fuel pump operation (no start)
HI...
The common cause of the problem that you related.
Is the FUEL PUMP RELAY " Called MAIN RELAY.
Is located : left side under the dash.
Is a BIG relay gray colour. with a connector of 7 or 8 wires.
I recomend replace the relay.
And letme know if you solve your problem.
I hope this information work on your problem.
Thank you for use fixya.
Posted on Jul 25, 2008
  • 3422 Answers
SOURCE: Ge Adora front load washer not working
I don't know how you could have got it into diagnostics mode by accident - - but here's how it goes . Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal
Posted on Sep 30, 2008
SOURCE: loud Buzzing noise
Sounds like something may have got past your filter and is touching the main pump impeller eg piece of broken glass or piece of plastic.I,ve even seen a spoon touching the impeller. You may have to take the bottom off the machine and remove the pump if you can,t see anything under the filter,Hope this helps. Regards Stefan.
Posted on Jul 08, 2009
SOURCE: USQ1102 pump gets power, buzzes, trips breaker
The motor-start capacitor is bad. This is a very common problem. It can be easily and cheaply fixed by replacing the capacitor. Replacements are usually less than $10.
See http://www.youtube.com/watch?v=ZEIv5ClLqXg for a step=by=step guide.
When you have the capacitor in hand, check the model# which is printed on it. Alternatively, you can Google the motor brand & model to find the parts list which will identify the right one. Then Google the part number, to find a seller.
Posted on Jul 13, 2009
john224
  • 1378 Answers
SOURCE: Pump justs makes a buzzing sound and does not
Either the start capacitor, start switch or winding, or perhaps some combination of the three is failing. You can take it to a local electric motor repair shop and see if it can be repaired or get a cost to replace just the motor and probably the pump seal. You would still save money compared to the cost of a whole new pump.
Posted on Oct 03, 2009
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
Car dies for no reason
i would check the fuel pump for proper pressure
Apr 19, 2014 | 1998 Honda CR-V
Hurlcon cx240
bad sensor and cell calsified need to super shock poool
Mar 19, 2017 | Pool & Spa
Fuel pump not always on
Did you reset the inertia switch that shuts pump down in case of collision?
Feb 18, 2012 | 2000 Mercury Grand Marquis
2000 mercury grand marquis 4.6 fuel
Voltage drop test the electrical circuit , do know how to do automotive electrical testing . Lose connection , resistance in the circuit , lose ground Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia Testing Electric Fuel Pump Problems with Voltage Drop Test
Feb 27, 2017 | 2000 Mercury Grand Marquis
2000 mercury grand marquis 4.6 Intermittent problem. 35,000. miles. Problem engine died several times wile driving. Also after car is parked from a drive will not start. Found that the fuel pump is not...
I'd have to test when problem is ongoing. When you first turn on key, no crank, you should hear the pump run for a few seconds then stop. For initial prime, the computer doesn't need rpm signal. Engine cranking, the computer needs to see rpm signal or it won't ground the fuel pump relay. W/o rpm signal, no spark at the plugs and no fuel injector pulse. I know your talking about fuel, but, when problem is ongoing, check spark and fuel injector pulse, engine cranking.
Intermittent problems are a pain, have to test when problem is ongoing.
Feb 27, 2017 | 2006 Mercury Grand Marquis
Loud Buzzing noise
Jul 08, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Sep 30, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
HI...
Jul 25, 2008 | 1993 Acura Integra Hatchback
Pool & Spa Logo
49 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
