Question about Cycling
Reset smart 10F cycle comouter - Cycling
Reset comouter after oil change
turn wheel hard to right with key in run and step on gas pedal three times oil life will reset
Feb 28, 2015 | 2008 GMC Sierra 1500
Wrong resolution on smart tv- cvd601
I made the mistake of selecting the largest of the resolution settings of 1920x1080-50Hz. The CVD601 DOES NOT HAVE A RESET BUTTON! You have to do all your business on screen. So to regain my setting of 1280x720-60Hz, I disconnected from my TV and hooked up to my computer monitor. At that point, I got my picture back and went to settings. Upon restoring the settings in TV Screen Resolution to: 1280x720-60Hz just click and exit. In the US everything is based on the 60Hz cycle. Hence the hickup when you pick anything in the 50Hz cycle. I hope this helps!
Jan 08, 2014 | Craig Electronics Craig Smart TV HDMI...
True T19 - Seems to cycle on and off too frequently. Has also not shut off twice and gotten temp down to 10F. Thanks, Robert
I'd look at the thermostat. Either bad or not mounted correctly. Start there and let me know if you need more.
Dec 19, 2010 | True GDM-12 Refrigerator Commercial
Any Motherboard driver for QDI Advance 10F?
Now get the drivers from the shop where you bought computer and install all your motherboard drivers as required.
The shop keeper will give you a CD disc of drivers.
Then install it.I'm sure that you will get sound better.
Apr 09, 2010 | QDI Group QDI Advance 10F Motherboard
Frigidaire freezer stopped making ice
freezer temp must be 10F or lower, feeler arm down, if icemaker is still not starting a harvest cycle there is thermal fuse inside icemaker that may have opened up.
Jan 05, 2010 | Frigidaire FRS26R4A Side by Side...
I have an icemaker in my refrigerator, but it is not making any ice. the water is on, so what could be the problem?
icemaker has to reach 10F (22 degrees below freezing) to start harvest cycle. a thermostat closes a circuit to a motor and heater to start the process. if there really is no problem with the water supply, problably icemaker is bad. also check fill tube freeze up.
Jan 03, 2010 | Whirlpool Refrigerators
What are the correct temps. for freezer and main refrigerator
Refrigerator should not be warmer than 40F. Optimal temps are 34F, this keeps your food cold without freezing it and slows down bacteria growth !
Freezer section no warmer than 10F. Normal temp 0F, optimal/recommended -10F (also for cold icecream) and for quick recovery in case of power outages.
I hope this helps.
Sep 25, 2009 | Frigidaire Refrigerators
Freezer is not cold enough
Here are normal temperatures - Freezer should not be warmer than 10F. Normally it should be 0F, however optimal temps are -10F and for hard icecream - I recommend -10F or colder since it gives a better recovery after a power failure.
Refrigerator temps no warmer than 4F - optimal should be 34F.
After ruling out door gasket seals and dirty condensers, the most common cause is a bad defrost system. If you remove your freezer panel you can look for over frosting on the evap coils - (after shutting down unit of course) try manually defrosting with a blow dryer until everything is melted - place back panel and run for a couple of hours. If cooling is back to nromal, your issue is defrost timer components / control board.
Make sure the evap fan is working properly as well. as your condenser fan (if applicable).
Sep 23, 2009 | Kenmore Refrigerators
Cycling Logo
118 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
