Question about Peavey Audio Players & Recorders
How to connect cd player to peavey xr500 mixer amp
4 Suggested Answers
Drummernick
  • 440 Answers
SOURCE: PEAVEY AMP 1400
mixer 1/4 in jacks unblaced to power amp signal then to speakers red always right black left
Posted on Feb 09, 2008
marsrover
  • 682 Answers
SOURCE: Connect a CD Player to the Peavey XR600 Amp
go to radio shack and get1-3-ft. radioshack gold series RCA A/V CABLE NUMBER(15-3030) OR(15-3031) IT DEPENDS TO DISTANCE BETWEEN PLAYER AND AMP.(ANY AUDIO CABLES WILL SOLVE THIS PROBLEM BUT GOOD QUALITY MEANS BETTER RESULT.
Posted on Mar 15, 2008
SOURCE: I have a Peavey XR- 600 Mixer amp. That has a hum
i have a xr600f and cant get any sound from it..
Posted on May 31, 2011
Hooking up other external systems
Peavey XR 1212 You may find helpful info from the Peavey site. I'm not sure how you want to configure your setup, but the tape out may be able to feed the power amp.
Mar 24, 2014 | Peavey XR1212 12 Channel Powered Mixer
I am trying to connect a computer to a peavey src 4026 to record sermons
Why not un-complicate the circuits by eliminating the soundboard first?
May 11, 2017 | Peavey Music
I want to know how to connect a powered subwoofer to the peavey 10 mixer
Connection is hooking up from mixer's main outputs (L,R) to
Subwoofer amp inputs.
Oct 10, 2013 | Peavey Electronics Peavey PV10 Mixer
I am not getting no output from peavey 16fx mixer. if i trun it off on & on i get signal for 2 sec
Theres a little switch next to where it says media in on your front panel just above the group sliders.This little button needs to be pressed down otherwise your cd won't come thru.
Feb 13, 2013 | Peavey 16FX 16 Channel Mixer
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Mar 08, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Can I connect this mixer to a main mixer with 17 channels that is connected to an amplifier?
Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output,  or monitor  send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
Feb 10, 2011 | Peavey XR 8600D Class D Powered Mixer
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
Connecting cd player to mixer
This should work. I use a similar setup for break music at small gigs. I would check the cable and the output of the unit itself again. .
Feb 21, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
66 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
shaqsatin
Level 1 Expert
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
