Question about Fitness Quest Integrity 3000 Air Rower
Need roller bearings for a voit rm/4 rolling machine
Why doesn't our laminator always roll?
It sounds like the control panel switch membrane( under the panel buttons) needs to be replaced. The bad sound may be your heat roller bearings failing. They dry out and start squealing. They also can cause your machine too slow down or stop. There are 2 bearings on either side of the laminator, 4 total.
Sep 08, 2015 | Gbc Heat Seal Ultima 65 Laminator 1710740
My allison transmision is making a grinding noise when in gear from the back end of the transmision
Sounds like a bearing problem. The gears are held in place by roller bearings, and they sometimes pack up. Working the machine with a bad bearing eventually grinds up the steel balls or rollers that the flanges roll on, and the bearing collapses completely. The bearing itself will announce its demise with a grinding sound, and worst case scenario the bearing is so far gone that the gears are running out of true with respect to one another, and this could be the grinding you are hearing.
Oct 01, 2014 | 2004 GMC Sierra
Belts aren't broke roller still won't roll
Belt dosent have to be broke it may be stretched. It needs around 30lbs of pressure to roll the brush on carpet.
If it dose not roll off carpet at all the brush bearing are locked up. You may be able to remove the roller and check theme. Most likely you wil need a new roller brush.
Aug 08, 2014 | Bissell 8910 ProHeat Clear View Upright...
Replacement wheels for voit rowing machine
I have a Voit RM 4 rowing machine, and the 6 plastic wheels under the seat are dried up and broken. Any one know of a replacement option?
Oct 10, 2011 | Exercise & Fitness
I have taken my Maytag Neptune-TL washer apart(model FAV6800AWW). The machine did not spin dry anymore do to the roll clutch bearings being frozen. When I knocked out the roll clutch bearings, I did not...
Hello datil7772 ,
Did you see this post? My series 16 machine did not use the upper bearing ring. What is 1st two digits of your serial number.
I believe that bearing ring is a plain bearing ring not a One-Way Roller clutch bearing as is in the Clutch Pulley. I refer to it as One-Way roller clutch but I believe I’m wrong can you confirm?
Any way the ears on that upper ring should go up into the tub slots in the bottom of the wash tub. I would be concerned about the reliability of you Clutch you may want to replace it. The post above has the clutch I recommend and the supplier with the best price. I also describe reassembly of the clutch in the machine. Good luck back and post back if
you have questions…… Rich
Info from the above post;
6.
Reinstalling the Clutch Pulley assembly is the most difficult part of the process. With a tight work area try a test fitment of seating (if used) the Upper Roller Clutch bearing with the notches into the bottom of the wash tub. Then insert the Spinner Shaft Coupler into that bearing rotating CW to reseat the coupler notches to the spinner shaft. Then the clutch pulley to the squared end agitator shaft. Rock back and forth the clutch pulley assembly with upward lifting pressure to reseat the clutch assembly. When the clutch assembly is properly seated you will feel a 1/16-1/8" gap between the Pulley face and shaft end as mentioned and shown on page 47 of the SM. On reinstallation, tighten Clutch Pulley bolt CCW to 96” pounds 8’ foot pounds (Snug no torque wrench required).
Nov 27, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Worn seat wheels on Tunturi 202 need replacing
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Jul 01, 2009 | Tunturi Exercise & Fitness
R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Mar 31, 2009 | Exercise & Fitness
Xerox Workcentre XD100 Accordion Jam After A Few Copies
What is most likely happening is the pressure and heat roller bearings and bushings are very gummed up.
When you remove a the fuser when its cold, try turning the heat roller gear, I would assume it is very very tight to spin.
What you can do it take the fuser apart, soak the pressure ( soft roller) roll bearings in some alcohol and then clean the heat roll ( aluminium) roller bushings and the end of the heat roll. Make sure you lubricate with some silicon lube the ends where the pressure roll mounts into the small holes in the nip fingers. That should help.
You can call a business called , ( you can google, The Parts Drop) and talk to Britt there. I am pretty sure he has the bearings for that machine. I don't work there, just have done business with them for years and they are top knotch.
You probably want to replace the gear also. Sometimes it can look really good, but be worn just enough to cause a problem.
Make sure you take a real good look at the condition of the rollers before you spend money replacing small parts, so that you don't wind up replacing 40 or so dollars worth of parts only to find out you do need the entire fuser.
Nov 29, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
I can't get the power brush belt on tight. Am I missing something?
I don't know what brand of vacuum you have, but the belts on most vacuums should be changed approx. once a year. The belt can look fine, but is stretched and won't have the necessary tension to turn the roller. It is possible that the roller is in need of servicing. If the bearings in the roller are fouled with dirt and hair, they will not turn properly and a new belt will not solve your problem. Take the roller out of the machine and turn the end caps by hand. They should turn freely. Once you've determined that the roller is o.k., install a new belt, turn the roller by hand to make sure that nothing is jammed and then try the machine again.
Feb 01, 2008 | Vacuums
Brush roller stopped rolling
My daughters is doing the same thing and the plastic at the ends of the brush bar melted just enough for it not to turn properly. You might want to chech that.
Nov 25, 2007 | Eureka 2961AVZ Bagless Upright Vacuum
Fitness Quest Integrity 3000 Air Rower Logo
95 people viewed this question
Top Fitness Quest Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Fitness Quest Exercise and Fitnes Expert? Answer questions, earn points and help others
