Question about Refrigerators
Water in my refridgerator
I seem to get water inside my fridge all the time, what could be the problem?
    President:
  • Refrigerators Master
  • 2,651 Answers
Common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Jan 26, 2009
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
Water is leaking onto the inside floor of the fridge. when u used the water dispenser it leaks even more
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
May 12, 2010 | Refrigerators
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water collection in fridge
.you need to check the drain to make sure it is not clogged or blocked that would stop the water defrosted from you evaporator coil from draining into the drain pan.rare occasions the unit will stay in a defrost mode while trying to cool causing alot more water to be draining.good luck with your fridge.let me know how things go for you.
Jan 22, 2010 | Refrigerators
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Sep 01, 2009 | Kenmore Refrigerators
There seems to be something leaking from the front bottom of the refridgerator, can it be feron, is it dangeours
freon is a gas at room tempurature. if the fridge is working, then it is probably water condensation. If the fridge is not working, it could be the oil inside the compressor.
Jun 28, 2009 | Refrigerators
Refridge leaking water inside it...
Should be a little drain hole in the bottom rear of the fridge. Use a pipe cleaner or somthing similar cos it,s probably blocked. Quite a common problem.
May 19, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refridgerated water spout suddenly stopped producing water
Have you changed the water filter. It should be located in the front loer grille of the refrigerator.
Jan 10, 2009 | Refrigerators
GE refridgerator
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
Jan 02, 2007 | GE GTS12BBPLCC Top Freezer Refrigerator
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
