Question about Dell Latitude D600 Notebook
How to change batteries on dell bluetooth mouse?
How do you take the mouse apart to change the batteries?
  • mcarchives Jan 26, 2009
    Thank you!!. There aren't any screws on this mouse but an almost invisible cap on the bottom back that slides back and off.
  • 41 Answers
Usually there is a catch on the bottom. Sometimes you need to take out a screw or two, but once you push on the catch it will pop apart.
Posted on Jan 26, 2009
Changing the batteries does not make the mouse work. the cursor is visible on the screen but will not move. what next?
Have you tried re-pairing your mouse? Should be a button on the bottom of the mouse and a button on the wireless antenna device. Or, If your using a bluetooth mouse make sure bluetooth is turned on, on your computer.
Jun 28, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Blue tooth icon missing from system tray now Dell blue tooth mouse wont work
You need to connect a wired usb mouse first and try pairing the bluetooth mouse again with your system by going to the control panel and opening your bluetooth device manager. Click add a device and press the connect button underneath your mouse. System should be able to detect your mouse. If that failed, try replacing the batteries with fresh ones.
May 24, 2010 | Dell Studio 17 Laptop
Dell Wireless Bluetooth mouse has stopped working - changed batteries - bluetooth light flashing - help
Try updating the driver if drivers are curropted, also check to reset button which is on usb dongle to synchronize, which may solve your problem.
Dec 04, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My dell keyboard with blue tooth connection
If there is no light on the Bluetooth keyboard it means there is a problem with it.
If the Bluetooth keyboard is not responding try to do the following:
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Keyboard
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth keyboard will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
Nov 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My dell bluetooth mouse stopped working. I replaced batteries, but does not work. I have studio laptop with built in bluetooth card
what OS are you running, is it vista? if so, I had same problem. the dell Tech had me uninstall service pack 2 and then the mouse would activate properly
Sep 29, 2009 | Dell U0636 Mouse
Dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
Jun 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless keyboard and mouse not working
Hello
Some wireless keyboards and mices have a button that enables the locating signal of the device, this button when pressed locates the receiver and initiate a pairing with the host. Look below you keyboard and mouse, and if your keyboard is a Bluetooth device, then check in your computer if the bluetooth is enabled and drivers are installed.
good luck
May 23, 2009 | Dell 0Y3740 Keyboard
CANNOT CONNECT WIRELESS MOUSE TO DELL INSPIRON 1525
make sure your usb ports are turned on in the bios
Apr 11, 2009 | Dell Inspiron 1525 Notebook
Dell optical wireless mouse locking
If your mouse is "locking" the two most likely causes are either due to a battery issue or a connection issue. The first is unlikely since you're saying it started just after you replaced the battery, but you might want to try again if you have other new batteries around that you can use. Also you could try Re-Pairing (if you have the bluetooth wireless keyboard/mouse combo that dell offers) the keyboard and mouse after reboot. step by step Instructions for re-pairing or fixing a corrupted are should be available on the Dell support website and vary depending on the exact model you have.
Jun 28, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Dell Latitude D600 Notebook Logo
123 people viewed this question
Alun Cox
