Question about Milwaukee 6460 10 1/4" Circular Saw With Case
Cannot find spindle lock for milwaukee 6460
Looking for a Milwaukee 48-66-1381 chuck kit with a 38-50-5075 spindle.
sure the age of the tool may have parts discontinued or superseded
this is a Milwaukee chuck kit you can buy
and a spindle on sale
try this Milwaukee parts supplier for a part or dimensions of the spindle/chuck you need
Milwaukee 1670 1 SER 472D Single Speed Hole Hawg Drill Parts 26309591-1jfwbypa2loxnuc0fythdbff-4-0.jpg
Oct 13, 2016 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
How can I remove worn spindle for replacement?
Yes much dirt inside its not work for
office workers who find this inferior work or afraid of making dirty hands but to do the job when you will do the job best is to must have a solvent cleaning machine to do this job or a great tub with solvent or benzine at least. and a brush .
Milwaukee 6537 75 SER 986A 75th Anniversary Super Sawzall Parts
Its Look likes you have already unmount pos 35 from pos 34 gear case
now first remove pos 55 bearing cap front unter gear case white or black cap on the drawing remove that first then you set(fixate) the small protruding part of the drive gear pos 45 in a bench vice. and then you can remove the pos 5 spinlock hex nut and then the wobble gear comes free. then the rest is to see that all parts have its positions beware of that .
There is the parts list for position neccesary zoom in if you want to see something in the drawing . IMPORTANT if you will now or in future replace the armature then replace also the great gear pos 45 and carbon brushes. if only spindle pos 51 then also replace pos 65 tube chassis. and pos 53 , 60, 61 ,66 , if you will choice the grease a good multi purpose grease and there should be quite a lot of fat inside the machine , replace also little o-rings which have not yet been mentioned concerning lubrication felt and o-rings.
Feb 27, 2016 | Milwaukee Hand Trucks Milwaukee...
Quick change clutch is locked
Push the rubber sleve off the drill bit and up the drill bit then the plastic ring. release the clip around the spindle. Slide the clip and chuck sleve forward and remove the ball sitting in the spindle. You should then be able to pull the bit from the machine. If it does not want to come hold the bit in a vice and tap the spindle off the end of the bit using a suitable punch. Rebuild chuck in reverse.
Jan 29, 2013 | Milwaukee Electric Tool Milwaukee 5359 -...
I need to know how to change the blade to my Milwaukee heavy duty abrasive cutoff machine.
Look around the housing where the switch handle bolts on. You should see a spindle lock pin. With the unit unplugged you want to push in the pin and when you go to tighten or loosen the blade bolt the spindle will lock into place. Sometimes you need to turn the spindle a bit for the lock to catch. Once you have changed the blade just release the pin as it is spring loaded.
Jul 13, 2011 | Milwaukee 6180-20 14" Chop Saw Abrasive...
MILWAUKEE 4253-1. HOW TO REMOVE THE SPINDLE #47 ON THE PARTS LIST. AFTER THE CHUCK AND GEAR CASE IS REMOVED FROM THE MOTOR.
The spindle is pressed into the bearing in the nose of the gear case. You usually need a hydraulic press to get them out. If the spindle gear, woodruff key and spacer come out easily (it may need a little prying pressure) you may be able to tap the spindle out with a dead blow/rubber hammer or with a piece of wood on the end of the spindle. If you hit the spindle directly with a metal hammer you can mushroom the end and it won't fit in the needle bearing in the service diaphram.
Mar 22, 2011 | Milwaukee Tool 4253 1 Drill 1/2 Mag Motor...
How do I remove the spindle gear to replace the
find a schematic for your tool and it will show you how things go together. you may need a press to press it out or a gear puller. if the schematic shows spendal and gear apart you should be able to remove the gear. if it shows all one piece, then you replace the whole thing.
Apr 10, 2010 | Milwaukee 1101 1 Drill 1/2 500 D Hdl
Milwaukee reciprocating saw blade piston turns, allowing blade to flip flop around. Can this be fixed?
yes it can, probably the spindle or the primary wobble plce I would also check the conition of the front bushings and also the rear. You can go to Milawukeetool.com for a parts exposion on this tool.
Mar 10, 2010 | Milwaukee Tool Milwaukee 10 Amp...
I have an old Milwaukee 6378 worm drive saw (8.25") and it leaks a little on the front end. Not much but it is caked with oil soaked sawdust. I am going to change the gasket behind the red plastic "hood"....
If you put in the gasket (p/n43-44-0240) like you stated, and install a lock spindle service kit (pn14-46-1365) that should cure most or all of the leaks. The lock spindle kit comes with 2 o-rings and a new cap,one o-ring seals the cap and the other seals the pin. The only other thing that leaks once in a while is the armature seal (p/n45-06-0280) but to change it requires you to dismantle almost the entire saw, it you don't see any oil around the motor then its probably ok.
Jan 21, 2010 | Milwaukee 6378 Saw Circ 8 1/4 15A Worm
How do you remove chuck?
There is usually a bolt inside the center of the chuck in addition to it screwing on the spindle. The bolt may be an Allen or Torx.
Jan 12, 2010 | Milwaukee Tool Milwaukee 1680 21 1/2"...
Milwaukee Polisher model 5460. Gear Case Replacement
you need to remove the pad first and then you will find 2 torx screws about a 25, remove them and the plate next if you have a dead blow hammer tap on the side of the gearcase where the screws were and the spindle assembly and bearings will jump out of the housing, then remove the 4 screws holding the gearcase to the motor housing and it will come apart. To reinsert the spindle assembly gently tap back into place with the hammer to reset the gears. Let me know if you need more assistance.
Nov 25, 2009 | Milwaukee Tool Milwaukee 5460 - 6 7/9"...
Milwaukee 6460 10 1/4" Circular Saw With Case Logo
Top Milwaukee Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Jim London
Jim London
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
