Question about LG LRSC26944TT 36" 25.5 Cu. Ft. Side-by-Side Refrigerator w/ Digital LCD Display & Jet Freezing Draw...
LG refrigerator lrsc26944tt error code ER FF
My LG frig. has been displaying the error code ER FF for 2 or 3 weeks now. I have been unpluging it for just a min. and it resets. some times it will go 3-4 days or 10-12 hours befor error ER FF comes back. Their have been no sound coming from it. Please help, don't have money of repair man.
  • Joe Sea May 11, 2010
    the ice dispensor flap stays open after you pull the glass away. I am a tech and I am trying to see if any other techs know how to get to and fix the flapper problem
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Posted on Apr 08, 2009
  • 410 Answers
Er ff means the computer is not sensing the evap fan motor running. the most common issue is ice build up in the fan. if you are able to remove eh rear cover of the freezer compartment you will be able to clear the ice manually, otherwise offload the unit and unplug for 8-12 hours to allow all ice to melt out. there are few reasons this ice built up most common is door left open or faulty seal. good luck peyton
Posted on Jan 26, 2009
    New Friend:
We have same issue with our LG. After complete de-icing by repairman, only works a few weeks. Then problem recurs. Per repairman this is known issue - he says information can be found in Training Bulletin TB46-150REV2 To solve problem long term he says to replace control board, grill assembly, and door gasket. This is being covered for the Kenmore version of the refrigerator even after warranty up due to manufacturing defect. We are now going to LG to request they cover our repairs even though we are out of warranty (by one month!) . I am never buying LG again.
Posted on Feb 24, 2013
  • carey902
    carey902 Feb 24, 2013
  • Julie Jul 22, 2013
    Yes, I got the same error code. I read your comments, and they were very helpful. Our frig was hot inside, and I worried about a fire. I think we'll look for a new frig, and definitely NOT kenmore or LG
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
Refrigerator displaying error "ER FF".
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
I have a samsun fridge and the code pc er came on and the light is not working nor the temp why????
"PC-ER" its a error in the PCB (computer).
Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
Samsung says that... if the code "PC-ER" appears on the display panel or if you cannot resolve the issue, the refrigerator needs to be repaired. Contact a Samsung service technician.
Hope this helps.
Jun 09, 2011 | Samsung Refrigerators
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
I have an LG SXS side by side refrigerator that will not dispense water. The display shows FR & FF. If the supply is switched off and then back on again the display resets for a period of time. Over...
Er FF - Freezer Fan Error - This can be caused byfrost accumulationon or around the freezer fan. Unplug the unit for 3-4 hoursto allowthis to melt off. If error code persists, call Customer Service.
Jan 20, 2011 | LG LSC26905TT Side by Side Refrigerator
We noticed the same error ER FF on our display this morning. And the fan was making the same loud-troubled noise.So far I unloaded the ice from the ice maker and turned off the icemaker. The noise stopped,...
If you turned off the ice maker, I suggest you unplug the ice maker connection cord so the frig system is not compromised by any default in the ice maker. Next, unplug the frig from the electric receptacle and wait 5 minutes, then re plug. This many times will allow the control circuit to reset itself and the failure/error codes will usually diappear (if nothing else is wrong).
Note: any time you disconnect power to a frig or air conditioner, always wait 3-5 minutes before restoring power to give the compressor time to settle before forcing it to start again; this makes a big difference some times. Good Luck, Macgivor.
Sep 20, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
LG LRSC26944TT 36" 25.5 Cu. Ft. Side-by-Side Refrigerator w/ Digital LCD Display & Jet Freezing Draw... Logo
5,899 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
