Question about Cuisinart DCC-1200 Coffee Maker
Its not making the coffee its just makes a little then stops
it looks like this, it makes alittle tiny bit then makes a rattleing noise and then gargleing then stop, i turn it off then turn it back on it makes alittle more then just stops, it just started doin this it worked for a year.
  • 5 more comments
  • beamer96 Jan 27, 2009
    same exact thing word for word, its less than 3 months old. makes about 2 cups at a time and then shuts off. turn it off and back on, does 2 more cups. haven't torn it apart yet, must be some kind of switch to turn it off when the water level get to the bottom that has gone bad, to new to be calcified i would think.
  • mykidsrfun Mar 11, 2009
    I had the same problem after 2 weeks with this Cuisinart Maker but had thrown away the box & receipt ~ so hubby went and bought ANOTHER one just like it so I could take the box to send it back. I had it for a month and find myself with the exact same problem. I just ordered new filters from Cuisinart too ~ last weekend!! It soaked in vinegar and I've tried to run it through off and on all day, thinking that if it sat and it was depoits, that would help. I have now resorted to Efferdent Tablets to see if that will clean it out because I have nothing to lose at this point....don't have this box or receipt either!! Won't buy another one of these!
  • ewmcdonald Mar 18, 2009
    I have the same problem, it was fine for about 8 weeks, now it brews about two cups and then just some steam and noise!
  • BobHSF Mar 20, 2009
    I have had our maker for about one year and have cleaned it regularly (have run vinegar through it), now I encounter the same "gurgling" situation and steaming out of the back....I am wondering if the piping is either corrupt or perhaps worn and hence this situation.
    Now a little water comes out and it takes what seems to be hours to make coffee.
    Any advice as I have (and do) enjoy the brand, it's been very solid until now, and unclear why it would break down now.
  • Anonymous Apr 27, 2009
    SAME PROBLEM HERE. THERES GOT TO BE A REPAIR, SOMEONE NEEDS TO TELL US.
  • Anonymous May 13, 2009
    Suddenly can't make a full pot of coffee, nor does the bubbly sound go off unless I turn off machine.  My machine is out of warrenty.  Is it worth repairing?  If so where-I live in NE corner of CT
  • reefer4747 May 25, 2009
    Tried brewing a pot of coffee this morning,only got about a cup of coffee,then the cleaning lite came on and it is still sitting here an hour later still "gurgling" and no coffee.What is with this rhing ??????
  • 8,596 Answers
You both may have deeper issues, but it is definitely not too new to be decalcified. It is very much worth a shot. I have a Cusinart coffeemaker and a Cuisinart espresso maker, and both of them needed to be decalcified in the first month (of course, I live in an area with hard water).
-Tha Mp3 Doctor
Posted on Feb 21, 2009
Try making your coffee the night before. I have the same problem with my Cuisinart DCC-1200 coffee maker. It shuts off before the brew cycle is complete. If I program the timer brew the night before and set it to start in the morning, the unit works fine. I had to change my routine a little, but now I still have nice hot coffee in the morning.
Posted on May 03, 2009
My drive side door inside is rattling when I drive it but I don't what is causing the noise on my montero sport
There is a connector on the frame of the car where the door locks onto when closed. It has 2 big phillip screwdriver screws holding it on. Loosen them a little and maybe knock it in just a tiny bit to make the door close tighter to the vehicle. Hope that helps.
May 15, 2014 | 1998 Mitsubishi Montero Sport
Gaggia synchrony logic making grinding noise
With these removable units, you must be very careful, the circular mechanism that does the running of the Y motion need to be properly alligned. You need to perhaps put the back of a knife in it and adjust until all the parts align, Then it must click in easily. If you have forced it in the clip will not release. you need to rattle it a little.
Sep 02, 2012 | Gaggia Syncrony Logic 74884 Espresso...
My Kerig brews a tiny bit and then stops. Can I use the vinegar solution on my B77 as is recommended for other B models?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 07, 2011 | Keurig B70 Coffee Maker
My keurig just quit squirting coffee. It heats up squirts a tiny bit then stops
heatman101
May 04, 2011 | Keurig Platinum B70 Coffee Maker
My LG over the range microwave makes a rattling noise when I am cooking. The sound is not there is the item I am microwaving is heavy.
This may sound a bit nuts, but remove the glass tray and support ring. Clean the wheels and ring. Also clean the glass and microwave surface where the wheels run. Any tiny bit of debris will stop the wheels from turning, and make a rattling noise.
If that doesn't help, you may need a new turntable motor.
Feb 26, 2011 | LG Over-the-Range Microwave
A rattling noise from the engine bay
Check the heat shields on the exhaust system. They get loose from the extreme heat fluctuations work loose and rattle. Especially the one between the engine and firewall where the 02 sensor screws in. It probably rattles less after warm up because heat causes expansion which makes it tighter. Hope this helps.
Apr 05, 2009 | 2003 Toyota Corolla
Thumping noise
There will be a different sound when you steam milk.
Aug 05, 2008 | Breville ESP8XL Espresso Machine
Flashing water light - will drain water but will not make coffee
Something is wrong on the coffee cycle side of the machine. Check the brew unit screens and and try doing a preground cycle with out inserting coffee. IF water comes out, I would looking into your grinder a little bit and try increasing the grinder size.
Espresso parts and service
www.cerinicoffee.com
Dec 08, 2007 | Saeco Magic De Luxe Espresso Machine
Cuisinart DCC-1200 Coffee Maker Logo
1,712 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
