Question about Panasonic SC-PM16 Shelf System
Attach dipole fm antenna to panasonic sc pm 16
2 Suggested Answers
WhiteFox4
  • 641 Answers
SOURCE: panasonic sc-pt760, can't select aux
I found an online manual you can browse through as I try to assist you with this problem:
http://service.us.panasonic.com/OPERMANPDF/SAPT760.PDF
When using your remote, press AM/FM then press the > or < keys to get to AUX or DVD
Posted on Jan 19, 2010
HTS 3560 / 12 - Any1 famililar with:- 1) Replacing Speaker Connector on Amp/ player unit. 2) 'DIY' Suggestions for replacing FM ANTENNA
Could you post a picture of the speaker problem?
The FM antenna is just a single wire about 1 metre long though you could use a dipole. It will take a standard Female TV Aerial Socket (picture attached).
Jul 12, 2016 | Cars & Trucks
Tip
Building your own Antennas
To build antennas for any frequency use formula L=234/Freq. Lets say 100 mhz. That would be L=2.34 feet or about 30 inches(close). Ok, Build a dipole antenna with a plastic insulator and 75 ohm Tv Coax. Take stiff alumnium rods or wire. Punch a hole into a plastic piece 4 inches apart. Insert Rods on both sides. Take shiny screws (Not Painted). attach Center Coax to Right side and Shield (ground) to Left side. Silicone these connections and use Black tape to wrap it good. Mount it on your Chimney or on a Tv pole 12-25 feet. Now, the coax coming into your house has to hook to your stereo by a 75 ohm match coil bought cheap at Electronic stores or Tv, radio supply stores. Attach coax by screwing it to coil and the two prongs screw to Back of your Fm Stereo. It will say ANT and GND. on back of Radio. You should pull in Fm stations better than indoor antennas and get farther away stations. It may have a 3 Db gain. Its the same for Cb radio --Just Use L=234/Freq. it comes to 8.5 feet(102 inches) Roughly. Its all Dipole Technology ..No Commercial antenna but will get decent results.
on Apr 01, 2011 | Audio Players & Recorders
I have a nexxtech am/fm/radio reciever model 1219178.I cant get any radio stations am or fm.was working fine in living room. now by window in basement.what can I do to get stations again?
Radios receive their signals from the airwaves. Since most homes are frame construction and have quite a few windows, radio signals tend to do well in first floor and higher settings. In high-rises, condos, and basements, where masonry construction is prevalent, signals are weaker or non-existent. If the radio has the ability to attach an antenna, you could use a dipole and fasten it up near or to the window to attempt to get better signal. This will or should help with the FM, but AM in that location is almost impossible. If the dipole doesn't work, there are outdoor antennas and there are some amplifier antennas that are available, but this increases cost.
Nov 20, 2015 | NexxTech Audio Players & Recorders
Fm aerial connection ?
Both of my Marantz receivers use a 75 ohm coax input. The receivers included a single wire antenna that simply plugs in. The plug is suitable for coax cable going to an external antenna. You can also get a small 75 to 300 ohm transformer that will allow you to use a dipole or other common indoor FM antenna.
Feb 11, 2015 | Marantz Audio Players & Recorders
I need to know what type antenna it needs
What you need can be as simple as a "dipole antenna", or as complex as an FM antenna on your roof. A dipole antenna looks rather like the letter T, with the top part of the T about 3' wide, and the base part long enough to reach your set. Make it out of lampcord, extension cord, etc. The connection looks like this:
the vertical bars are connections on the ends of the "T", and the base connects so it all makes a loop. The size isn't really critical.
You can buy one for under $10
May 06, 2014 | Sharper Image Slim One-CD Stereo with...
Show me a pictorial diagram of a dipole antenna connected to a stereo reciever
You didn't list your receiver model number, but here's a generic picture of how you would connect an indoor FM dipole antenna to a Kenwood receiver. These antennas should be available at most home improvement stores or from Radio Shack. They cost around $10.00, maybe less.
Depending on your model, you may have use some adapters. Ask the store staff for help.
Aug 18, 2012 | Kenwood Audio Players & Recorders
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    Someone give me a tv antena can i make it a fm radio antena it has no wireing on it if i can how do i run the wire ?
    there is bended rod called as dipole in ur antenna..both ends of dipole should be connected by a coaxial cable. connect it to ur fm recivers antenna. to have much gain cut both ends of directors which are strait pipes (2 to 3 cm)
    Mar 10, 2010 | Televison & Video
    No FM reception on CMT-ED1 Sony shelf system
    There is hardly ever an internal FM antenna -- only AM. You'll need at least one of those twin-ax dipole antennas (there's one with every receiver bought).
    You can test the concept just by putting a single piece of wire on each antenna terminal -- when you do this reception should improve immediately, but will not be as good as with the dipole antenna.
    May 27, 2009 | Sony CMT-ED1 Shelf System
    Panasonic SC-PM16 Shelf System Logo
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
