Question about Westinghouse WST1550 Wired Deluxe Upright Vacuum
Prices on Westinghouse WST1550 vac parts 40008 & 40020
Prices for WST 1550vac parts 40008 & 40020
I need a new bin filter mine smells like mildew i washed it like it said and it now stinks.
Posted on Feb 27, 2009
The brush is not moving is that mean the belt is not working
Yes, the belt is probably too loose or broken...
replace the belt first before trying anything else..
heatman101
Aug 04, 2010 | Westinghouse WST1550 Wired Deluxe Upright...
I need vacuum cleaner bags for a WST 1300
call a vacumn or small appliance repair shop most vacumn repair shops will know what bags you need esp if they service your model or may be able to tell you who to call
Dec 18, 2009 | Vacuums
How do I remove the housing cover on a westinghouse vacuum?
Remove clear snap-in lights lens. Remove both lightbulbs. Where the bulb sockets are there is a screw, remove them. Then simply pull up on the housing from the rear where the wheels are and remove the top cover.
Dec 28, 2008 | Westinghouse WST1500 Wired Special Edition...
Parts
TheFantom Cyclone XT was originally manufactured by Fantom Technologies,Inc. that closed in October 2001. The replacement for a Fantom CycloneXT would be Westinghouse Wired Deluxe Edition (either a WST1550 or a WST1551). These replacement products are now handled by Salton Inc. Perhaps you may inquire from them:
  • Salton Inc.
  • 1 800 616 8689
  • salton@saltonusa.com
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 20, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Parts replacement
This the hood or top cover. There some screws on the bottom as well as on the top, then it comes off.
Aug 13, 2008 | Vacuums
Broken Belt for Fantom Crosswind 600XL
Hello, your Fantom vacuum will take a Panasonic U vac belt, to replace it, their are two screws in the back, one on each side of the back of the housing, take out the two screws and lift off the top hood, and the vac belt is on the side, remove the brush roller clean any debis away, put the new belt around the metal motor shaft first then around the brush roller, and pull down into the housing, make sure it locks in evenly, then turn the roller to make sure it moves freely. then put the hood back on front first, hold down and put the screws back in, in the back. now your ready to vacuum. Any question or more help I can give, please call 1561-848-3387 Thank you, Teresa.
Jun 16, 2008 | Westinghouse WST1550 Wired Deluxe Upright...
Fantom Cyclone wiring
The only sure way recommended (and probably the safest) would beto get a service manual or at least a schematic diagram. The FantomCyclone XT was originally manufactured by Fantom Technologies, Inc.that closed in October 2001. The replacement for a Fantom Cyclone XTwould be Westinghouse Wired Deluxe Edition (either a WST1550 or a WST1551). These replacement products are now handled by Salton Inc. Perhaps you may inquire from them:
  • Salton Inc.
  • 1 800 616 8689
Jun 08, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
WST 1600A
It sounds like there is a clog. If there is no air flow it could be overheating.
Feb 23, 2008 | Westinghouse WST1600 Upright Vacuum
How do I open the vacuum assembly?
you have to take the headlight lenses off with a small screwdriver. then a philips screwdriver to take the 2 screws out. one each side. then remove the foil shields on each headlight . then snap loose the rear plastic clips on the cover and it will come right off. it took me an hour to find out how and 10 minutes or less to take it off. watch for the micro switch on the circuit board being worn out.it will stop the roller brush from turning.its a dollar part at any good electronics store ,but will have to be soldiered in or service might have a few from the westinghouse line .so will a broken belt which is a special grooved belt available from fantom at 18007987395..
Jan 11, 2008 | Westinghouse WST1550 Wired Deluxe Upright...
Westinghouse WST1550 Wired Deluxe Upright Vacuum Logo
191 people viewed this question
Top Westinghouse Vacuums Experts
Kevin Getz
Kevin Getz
Tom Chichester
Are you a Westinghouse Vacuum Expert? Answer questions, earn points and help others
