Question about E-Machines eMachines Desktop PC
Computer promblem my computer is not bootup an fans are not coming on
  • 741 Answers
If you do not hear any fans then turn if off immediately before it overheats your CPU and motherboard. You will need to replace the power supply. Any repair shop can do it for a reasonable fee.
Rate this solution before you log out.
Posted on Jan 26, 2009
Emachine 1200-06 desktop computer plug in power supply cord computer fan starts up and hard drive sounds like its running power light on but cannot turn off and will not bootup or monitor will not come on...
Mike, for the problem you have this is the wrong forum. Way too complex for this site. Go here: www.suggest-a-fix.com, register and post your problem in the Hardware section. And, please, use periods; your post is very confusing without proper punctuation.
Aug 13, 2013 | Washing Machines
04 KIA SORENTA ac coolant fan stays on even if when car is shut off....
There has been known promblem with the 03- early 05 sorento of radiator fan staying on even after engine is turn off, it is claim to be a electrical malfuction in the engine termalstat. However you may just need to check your coolant level and fill it up as there is also a promblem to the sorento's having a leaking radiator coolant resevior too. Pretty much I own a 03 sorento, and it has been nothing but promblem, but glad I got rid of it. However like I said, check your coolant level, and fill it up with 50/50 coolant to recommended level. Should be able to solve the promblem, since it seems your engine is lacking coolant and is overheating, and the fan turn on automatic even after you have shut of your car to help cool it down.
Feb 02, 2011 | 2004 Kia Sorento
Desktop fans will turn on but dont boot up or turn the monitor on allready replce the video card but did not help
Hello there,
OK this problem could be many things or could just be the input on the monitor so lets start at the beginning and go from there one step at a time making sure we check it all .
also i could use more information do you hear the hard drives going i know you said you can hear the Fans so we know the power supply is working on the Fans but is it working for the Hard drive's? System make and model if you have one, if you did a home build give me the system Specs.
Step: 1 Check the connections all the wires/Cables the Power cord make sure both ends are plugged in correctly, check the Monitor Cable Making sure the VGA is also plugged in correctly both Ends.
Step: 2 Check the input on the Monitor if you are using VGA make sure you are on the correct input and so on .
Step: 3 if you have another monitor to another PC or maybe an older one connect it and Test to see if you have a bad monitor .
if all these Steps Fail let me know and we keep going . i hope we can get this problem Fixed
Jan 27, 2011 | HP Pavilion Elite m9660f PC Desktop
Externalseagate 250go not open how to solve
If you cannot open or see the harddrive when you connect it to your computer after it is powered on then that is the external harddrive itself. First, check if the power connection is connected and the usb cord connect correctly. Then see if any lights come on on the external hard drive. If lights does come on and still nothing showing or coming on to the computer, then your harddrive is history. Seagate makes one of the worstest hardrive. You can google this up about seagate promblem and there are thousand out there who have this same promblem. I know this because I have the same promblem you have.
Jan 17, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My motherboard GA-8GGEM800 no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
my motherboard 945gs no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
Oct 28, 2010 | Intel Motherboard
The CPU Fan stop after the pc boots
The fan will only run when needed to cool the computer. Fans normally run at full speed during bootup, but turn to low speed or off after bootup if not needed. Is your computer running hot enough that the fan SHOULD be running?
Sep 07, 2009 | Acer TravelMate 290 Notebook
Fan overspeeds when power is applied--precludes bootup
maybe your fan/computer is dusty., give it a little clean with some compress air.
Jun 24, 2009 | Dell Dimension 8400 PC Desktop
Computer won't boot
turn off the system remove all the cables from the back of the computer press and hold down the power button for 10 seconds now connect just the poer cable and try to tun on the system and as soon as it turns on tab the F8 key on the keyboard and then boot into last known good configuration
May 28, 2008 | Computers & Internet
Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Feb 22, 2008 | Gateway 960 Series (gtwy960) Server
Intel p4 3.0ghz with 800fsb fan makes more noice
Hello Prask, Cooling the Intel's LGA775 CPU presents quite a challenge due to it's high operating temperatures, and while the ideal solution would be to use water, not all of us are ready to make the jump. The best solution I found for an easy replacement of the stock cooler is nMEDIAPC ICECONE Pure Copper CPU Cooler. It is an easier install than Thermaltake, and is just as quiet. You can find it here for the best price: http://www.directron.com/icecone.html Let us know if you need any additional assistance. Best regards, nightdiver
Aug 16, 2006 | Intel Pentium 4 630, 3.0 GHz...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
