Question about Motorola T8500 Two Way Radio
Motorola T8500 Communication Problem
When I press and hold the PTT, it beeps and cuts out. My Partner can not hear a thing I say. I can hear my partner fine, both radios are programed to identical channels.
  • Motorola Master
  • 1,654 Answers
Check your interference eliminator code, and also your Qt filter. Try setting both to the off position (zero) and see if you have the same problem. Another thing to check would be your batteries and battery contacts.
Posted on Jan 26, 2009
    Problem Solver:
  • 4 Answers
Agree with eradiostore, check your batteries and battery contacts. Remenber to turn off the radios before charging.
Posted on Jun 12, 2009
T8500 Backlight
Here is a link to the user guide: http://www.giantintl.com/ContentManage-new/manuals/Moto/T8500%20English%20only%20June5.pdf
I did not find anything mentioned about the backlight function. However, on other TalkAbout models the backlight will automatically illuminate when you press any of the buttons other than the PTT and the musical note, and then the light will remain on for 5 seconds before automatically turning off. I do not know if this is the same on the T8500.
Best regards.
Feb 22, 2013 | Motorola T8500 Two Way Radio
Motorola talkabout t5710s won't recieve
The question I would ask is:
How close are the two radios to each other when you contact from one to the other?
A distance between the two radios of about 10-15ft, preferably more is desirable to achieve audible results, having the closer than 10ft, causes one to cancel the other out, so you either hear static, feedback or nothing.
Try 15ft of more distance between radios and see what happens.
Pls feel free to post the results here on the two way radio forum, as I'm interested to find out what happens.
Cheers, Peter@FixYa Team
Nov 29, 2012 | Radio Communications
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
To turn the tlk confirmation tone off... it does not work holding the - sign and turning it on now what?
Just read your message a second time. Is the sound following the release of the PTT button? If so, it is indeed the Roger Beep (aka talk confirmation tone). If holding in the minus button while turning the radio on does not turn it off, there might be something wrong with the radio, such as a one of the other buttons being slighty stuck. Or you have your keypad locked. To unlock the keypad hold the menu button in for 3 seconds until the lock icon disappears.
Another thing which will make a noise during or after transmitting is the low battery beep. You might check your batteries. Old, bad, poorly charged or defective batteries can cause this.
fyi: Some users might think the Call Tones are the Roger Beep.
Lastly, there is a PTT Timeout beep which will occur if you hold the PTT in for more than 60 sec while talking.
Hope one of these items is of help to you.
http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Best regards.
Oct 13, 2010 | Motorola Talkabout T6500 (7 Channels)...
When I press the PTT button it will not beep after i talk
either that or take out the batterys and it will reset ist selft
Aug 08, 2009 | Motorola Walkie Talkie 2-Way Radio
T8500 no recieve transmit vibrates when PPP is pressed
http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Try checking the vibra call settings for your vibrating issue. Also, as for the radios not communicating with one another you should check the programming of the frequency, interference eliminator and the Qt filter. All radios must be identical to work together.
Apr 27, 2009 | Motorola T8500 Two Way Radio
PTT Button cuts me off
Among the things which might be wrong with your radio, you could have an intermittent PTT button or a weak/bad battery. The PTT button has an internal button attached to the component board. Over time the button wears out from continued use, or it gets bent further way from the external portion of the button and simply doesn't make good contact. Also, a weak battery can give the same symptoms, as it takes more energy to transmit than to receive. Try a known good battery in the radio and see if the same problem persists. Either way, a visit to your local dealer could probably give you a free diagnosis.
Apr 02, 2009 | Motorola Walkie Talkie 2-Way Radio
Problem with Motorola t8500
Check your Qt filter setting. It works best in the "off" position.
Jan 17, 2009 | Motorola T8500 Two Way Radio
How do you go to silent mode?
There are two different kinds of beeps you can control, the "roger" beep and the "button" beeps. Below is an excerpt from the owners manual explaining the simple procedure.
“Roger” Beeps/Talk Confirmation Tone
When you turn this feature On, your two-way radio transmits a unique tone when
you finish transmitting. It’s like saying “Roger” or “Over” and lets others know
you have finished talking. If the person you are talking to does not hear the talk
confirmation tone, you can enable it by pressing and holding + (plus) as you turn On
your radio. Now, whenever you release the PTT, you let your friends know you have
finished talking by transmitting a “Roger” Beep tone. “Roger” Beeps will be
disabled as the Default Setting.
Note: To toggle the Talk Confirmation Tone feature, turn your radio Off and then
back On while pressing and holding + (plus) .
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press - (minus) and
hold . To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the - (minus) . On is the Default setting.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T7100_User_Manual_E.pdf
17
Nov 28, 2008 | Motorola T7100 2-Way Radio
UNABLE TO COMMUNICATE
It is likely you have the Interference Eliminator Code (aka Private Line or PL) set differently among the 4 radios. Your T8500 has 22 built in frequencies (noted by the BIG number on your screen) and 121 selectable PL codes (noted by the small number below the BIG number on your screen). All four of your radios must match on both numbers to communicate.
Use the menu button until the code starts to flash. Use the + or - button to select the code. Once you have selected the code you can press the PTT button to lock it in; or you can press the menu button to continue programming other features.
You can find a PDF of the user manual at http://snovalleyarc.org/pdf/FRS%20Radio%20Manual.pdf
Aug 20, 2008 | Motorola T8500 Two Way Radio
Motorola T8500  Two Way Radio Logo
271 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
