Question about Pioneer CDJ-800MK2 Turntable
CDJ 800MK2 The cue button has stopped clicking properlly and is now very sensitive so that even a minor shock can make the cd player cue itself.... the cd player still plays fine and does everything normally besides the problem mentioned above.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 65 Answers
This is the most common problem of Pioneer CDJ players, and it is natural wear. The small tact switch underneath the cue button is damaged. (sooner or later the play switch will break down as well)
Solution 1:
If you have soldering skills, desolder the old tact switch and solder a new one. This is the spare part:
http://www.artaudioparts.com/product/dsg1079
Solution 2:
If you do not have soldering skills, and still want to do-it-yourself you can change the whole pcb with the switches on it. This is the spare part: http://www.artaudioparts.com/product/dws1386
This way you get brand new switches for cue, play, forward and rewind which they usually break down as well in the future.
Posted on Nov 21, 2013
    Problem Solver:
  • 10 Answers
I have come across this problem quite a few times. 9 out of 10 times it has been the cue button being warped.
Posted on Jul 25, 2008
Call up pioneer support and ask them for the "switch that goes behind the cue button". it's about 2 dollars and when they ship it to you take it to your local audio repair center and it will take the guy about 20 minutes to unsolder the current switch and put the new one in...
Posted on Apr 23, 2008
Check the outer plastic casing a smine did this too, but then spotted casing slighty warped with heat, so was causing button to stick and jam bit.
Posted on Dec 10, 2007
Hi it sounds like your cue button tact switch is worn out,this is very common for tact switches to get worn if it gets constantly used. regards. paul.
Posted on Sep 04, 2007
The cue switch has to be cleaned by a technician. if that doesnt work. replace the cue switch.
Posted on Jul 18, 2007
SOURCE:
Where is the button/knob set up to play single song verses continuos songs from a cd on Pioneer cdj mk..
The button you need is the Auto Cue button, which is to the left of the top display. Press and hold to turn auto cue off, which puts the player into continuous mode. This button is also the Time Mode button.
Hope this helps
Jaye
Sep 17, 2011 | Pioneer CDJ-1000 CD Player
Pioneer cdj 800 mk2 needs new cue button needs to be local to bradford or leeds how much ? & where please :~)
PART NUMBER IS DAC2059 This also includes the play button.you can order from pioneer parts on line
Apr 16, 2010 | Pioneer CDJ-800MK2 Turntable
My cue button on my cdj 1000 mk2 kept jamming so i got some foam cleaning stuff from a dj shop and sprayed it on the cue button now it started going mad skipping traks, playing in reverse. i think that the...
cue button sticking sounds like the button on the pcu board needs replaced, I would clean all the foam stuff of if possible, as for the screen not working sound like some of your wires have come unconnected easy fixed just plug them back on to the pcu board
Mar 28, 2010 | Pioneer CDJ-1000 CD Player
Cue button is sticking as well as all other
There is no other option than cleaning.
The player must be taken apart to clean those knobs and housing.
Kind regards,
Gerard
Mar 18, 2010 | Pioneer CDJ-200 CD Player
MY CDJ 1000 KEEPS CUEING ITSELF
Seems that the switch under the Cue button is dirty, or broken.
Regards,
Gerard
Jan 10, 2010 | Pioneer CDJ-1000 CD Player
New CDJ1000 MK3 freezing and then turning itself off
CDJ 1000 mk 3 freezing while playing tracks and sometimes freezes when a cd is inserted. The orange cue light comes on but the green play doesnt. Any ideas?
Thanks
Sep 25, 2009 | Pioneer CDJ-1000 CD Player
Queing up on cdj 200
In order to set a cue select th button IN/REALTIME CUE once you do that you an press the CUE button located next to the play buton.
Dec 28, 2008 | Pioneer CDJ-200 CD Player
Cdj 1000-mk-2
Could be either the Track skip switch has collapsed and is thus over sensative or the button bank is broken and the track skip switch is being pressed when the cue button is used.
Could also have liquid spillage on the circuit board which cause all sorts of random problems
Oct 21, 2008 | Pioneer CDJ-1000 CD Player
ON MY PIONEER CDJ-1000MK2 MY CUE BUTTON IS VERY SENSITIVE... I DON'T KNOW HOW TO FIX THIS, I KNOW EBAY SELLS THE PART HOWEVER IM NOT SURE HOW TO REPAIR IT MYSELF AND OPEN UP THE CDJ.
Replace the cue tac switch or worst scenario replace the cue play board.... takes 5 mins to open solder and fit back together or 2 minutes to replace board
Hope this answers your query
MBI
01273 607384
Jul 14, 2008 | Pioneer CDJ-1000MKII CD Player
Cdj-500ll cue button repair
the faulty button will not stop it from playing well... replacing them is not hard so long as you have some experience with a soldering iron.
Clean the laser lens with a cotton bud wet with windex... then use a dry one to be sure no residue is left. If it still mistracks... new optics required!. You willl need a pioneer service agent to do this for you. A little complex for the first timer :)
Jan 08, 2008 | Pioneer CDJ-500II CD Player
Pioneer CDJ-800MK2 Turntable Logo
512 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
