Question about Samsung DV448AGE Gas Dryer
Where is the thermal fuse located on a Samsung DV448AGP dryer?
3 Suggested Answers
protek480
  • 1714 Answers
SOURCE: I have a brand new samsung DV448AGP dryer. It
A bit difficult to do. If yo remove the back panel and look at the exhaust duct to determine if you can swing it 90 degrees to the other side?? It may be possible but you'll have to look. Then switch it to the other side. Then of course you will need to cut a hole for it to exit the machine. That's the deal to get it out the other side.
Posted on Jul 25, 2009
heatman101
  • 43501 Answers
SOURCE: Samsung DV448AGE / DV448AGP /
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Aug 21, 2011
My Samsung electric dryer runs but doesn't get hot
Clothes dryers usually have one of three issues when they fail to heat.
Taking a good electrical meter ( with ohms readings), check first the heating element.
If it checks good, then try all of the thermostats and the fuse. (There may be as many as 5 thermostats.)
You will need to unplug the wires off of each of these items that you are testing before you test them.
Whilst you are looking, be sure to test the two hot leads from the circuit breaker box, because one of the two hot lugs is for the machine operation, one is for the heating element.
God bless your efforts.
Jan 19, 2016 | Samsung Dryers
Heat will start for a few minutes then stop and dryer will continue to spin with cold air.
You must have a blockage in your vent line between back of dryer to the outside or a kinked vent hose or a blockage in your blower wheel cover.
Jul 16, 2015 | Samsung DV448AGP 7.4 Cu. Ft. Gas Dryer -...
Where is the thermal shut off fuse located and what does it look like. DV331AEW/Xaa
The thermal fuse is located on the blower housing. You should check out this link to www.repairclinic.com
for a lot more info on this and other possible items that could cause no heat. The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160c44d1067187/Model-DV331AEW-Samsung-Dryer-Fuse-Thermal-Fuse-Breaker-Parts
Good Luck!
Rich Lilja
Dec 03, 2014 | Samsung DV331AEW Dryer
Thermal fuse location
Ok go to this web page read the instructions for testing, then go to the sears.com page, parts direct and look up thermostats and go to the diagram for locations and test
http://www.ehow.com/how_2377924_test-dryer-thermostat.html
Jan 05, 2013 | Samsung DV219AE Dryer
SAMSUNG DRYER NOT HEATING
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 16, 2011 | Samsung DV218AEW Electric Dryer
Samsung DV448AGE / DV448AGP / DV448AGW Gas Dryer thumping problems on rotation
heatman101
Aug 20, 2011 | Samsung DV448AGE Gas Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Samsung dryer blowing thermostats, constantly
you may need to replace both thermal fuses and or the heating element itself but check to make sure you have the proper temp rating for the thermal fuses
Feb 20, 2009 | Samsung DV337 Electric Dryer
Samsung DV448AGE Gas Dryer Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
