Question about iLO DVD Recorder DVDR05
When i place a recordable dvd it reads "no disk"
I started with memorex dvds and they would'nt work so i got Sony and they came up "no disk" model:dvdro5
    Master:
  • 416 Answers
If you have +R/RW you can use only +R or RAM DVDs.
http://www.walmart.com/catalog/product.do?product_id=3610576#Specifications
Also check the allowed maxximum recording speed (refer the manual, please). If you have for example 4 you can not use disc higher when 4 (it has to be marked 1-16)
If you use 2.7 you should use only discs there it marked 2.7 speed etc
If everything seems OK you need to use CD/DVD clening disk ($6 Walmart)
Please kindly let me know if you need more info. I am here to help
Good Luck
Posted on Jan 26, 2009
My 4 year old Sony RDR gx 300 burns fine on old Memorex , Fuji DVD R s but bought some new DVDs by memorex and Maxell and both won't formatt . It gives the message that disk is dirty or disk error ....
The laser on your drive is probably beginning to go out of alignment.
A plastic grub screw holds the laser carriage at the correct angle on the slider rods. Over time, this screw will get worn down and the laser carriage will begin to lean too far over to one side. This grub screw will need to be tightened slightly to bring the carriage back to the correct angle. I suggest turning it a quarter of a turn (clockwise) and testing it. Repeat a few times until it works correctly.
Sep 30, 2010 | Sony RDR-GX300 DVD Recorder
New DVDs - New Problem
Same speed U bought 1-4x 1-8x 1-16x make sure have same speed disc.
Dec 17, 2009 | Sony RDR-VXD655 Recorder
WHY DON'T SONY RECORDABLE DVDS PLAY IN SONY DVD PLAYERS? I USE THE SAME PROGRAM TO BURN MEMOREX AND SONY DISCS, THE SAME DVD+R 120 MIN/4.7GB(OTHER THAN THE BRAND BEING DIFFERENT), AND i HAVE HAD NO PROBLEM...
all dvd recorders are very very sensitive when comes to which disc is fed to them......you say sony is the same as memorex is the speed the same 4x-16x, may i also suggest maxell, dynex and vertabram
Oct 23, 2009 | Sony SLV-D300P DVD Player/VCR
DVD recorder wont record
The instruction manual says it strongly recommends for good quality recording : Sony Maxell and TDK and has been been tested for Verbaitim as well.
Nov 11, 2008 | Funai TruTech DVDVCR Dual Recorder
Invalid disk
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's but avoid memorex brand. Usually any other cheep brand will work.
May 04, 2008 | Gateway AR-230 DVD Recorder
Firmware update
Sorry to hear about your problem. I do own this model too. I have not gotten the update myself. I just started using the dvd recorder.I bought a pack of dvds (Ativa) and now I need to return them, they are not supported by this dvd player. I called the 800 number and they told me some of the dvd brands it supports: JVC, TDK, Memorex, Maxell and Sony. I know Sony works, because I used them before. I also read "Vibratim" brand from Sam's Club works.
Nov 26, 2007 | Sylvania DVR90VE DVD Recorder/VCR
Samsung dvd-r130
I had the same problem and after reading and trying allot of disks I found the following to work.
Used Maxell - RW disk. Did a complete format on my computer (takes a while). Burned a DVD using Vista DVD burner with only a Jpg as per one of the other posts. Once the disk plays. Stop and goto disk management and format using DVD-V (VR did not work).
I know its not pretty but at least its better than throwing it in the garbage bin.
Oct 29, 2007 | Samsung DVD-R130 DVD Recorder
Blank disks won't record
FIRST HAVE THE LASER LENS CLEANED
THEN USE MEMOREX DVD-R THIS SHOULD SOLVE YOUR PROBLEM
Oct 20, 2007 | Panasonic DMR-E50 DVD Recorder
Unknown disc error message
OKAY GUYS TRY USING THIS VERY COMPATIBLE MEDIA
(MEMOREX BRAND DVD-R) THIS WILL SOLVE A LOT OF YOUR PROBLEMS
Aug 27, 2007 | Televison & Video
iLO DVD Recorder DVDR05 Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
