Question about Philips 9P5544C 55" Rear Projection Television
9p5544c102 phillips magnavox - picture went out
The television's picture has slowly been getting dim. the other night it went out completely. sound still works but no picture. are there bulbs for this one that need to be replaced?
  • Philips Master
  • 3,459 Answers
Common problem. Goto www.TvRepairKits.com for a kit + instructions.
Posted on May 07, 2009
Picture on my magnavox 9p5544c102 is fuzzy with green tint
Its the CRT coolant which needs replacement. You can get the Phillips CRT coolant kit at www.tvrepairworld.com which contains the Coolant for all three CRT's plus has the CD with instructions.
Jul 14, 2010 | Philips 9P5544C 55" Rear Projection...
Phillips/Mag Projection TV-9P5544C102 no pic/sound /pwr light on
John, my thoughts is something in the main power supply. I don't know what an opto chip is but I've heard of Optocupler IC's.
May be a good idea to give a call to some local TV Repair Shops especially ones that work on Philip's and see if you can speak with a tech to see what their thoughts are on what the problem is and what a repair cost may be.
The issue is one of hauling it to the TV shop or having them come out to you.
Blessings,
A/V Media Guy
Nov 20, 2009 | Televison & Video
Picture faded model number is fp4620w103
This sounds like the coolant fluid needs to be changed - the coolant turns milky after awhile and you'll get a dull image.
Google TV repair world . com and look for philips/magnavox coolant replacement:
PHILLIPS CRT Coolant Replacement Kit This is the complete coolant kit for Phillips CRT rear projection televisions. Kit contains 48oz of top quality High purity optical grade coolant with complete detailed instructions produced in clear easy to understand terms with detailed photos and illustrations that takes you through the process step by step safely dischargeing the CRTs and eliminating the need for complete realigning proceedures.Restores the vibrant colors and focus issues commonly associated with coolant that needs replacement
Oct 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
61 inch phillips magnavox tv with no picture or sound
Its a common problem with this model.
Goto www.TvRepairKits.com and get their kit + instructions for the shrinking video problem.
Jun 17, 2009 | Philips Magnavox 9P6034C 60" Rear...
Sound but no picture 60in phillips television
I beleive you can get a chip to fix this problem from www.magnavoxhelp.com.
Aug 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips TV Foggy and no in between bright and dim
You will need to replace the CRT coolant and your color, and clarity will be restored to like it was when it was new this is a common problem for Phillips and magnavox rear projection TVs. You can get the complete kit at the following link which contains the 48 ounces of CRT optical coolant and a CD with the instructions on how to do the proceedure with pictures. They alos have free on line instant messageing tech support just in case you need additional help. And the entire kit cost less than just one tech comming out to look at it. Heres the link its listed under their repair kits catagory.
http://servicemanuals.vstore.ca/
Jul 07, 2008 | Televison & Video
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Philips 9P5544C 55" Rear Projection Television Logo
247 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
