Question about Dewalt Heavy - Duty 10" Wet Tile Saw - D24000
How to un glaze a diamond blade - Dewalt Heavy - Duty 10" Wet Tile Saw - D24000
Blade tracking for diamond laser 3000 - blade keeps coming off regardless of how many times I set knobs
There are several factors why blade snaps. It could be due to faulty adjustment of the guides or feeding to fast.
But sometimes, it could be also the quality of the blade. I have Haltbar blades from sawblade.com , the best quality .
make sure everything is set up properly and consult you speed and feed charts
for proper cutting rates. Try also to check if it is really properly tensioned ,read this blog ,this might help you : http://bandsawblog.com/blade-tension/
Dec 28, 2012 | Diamond Tech Drive Belt for Diamond Laser...
When I am making a cut, the blade will drift to the right making it difficult to make a straight cut. What would be the cure?
It's probably time for a new blade. If you are using a toothless diamond coated blade it can be difficult to see that the diamonds have been rubbed off. It drifts because it cuts more easily on the side of the blade where you have more diamond left. Be sure to use enough water to keep the blade from shedding it's diamonds too soon.
Dec 17, 2012 | Target Saws
Blade slips and doesn't turn, but the saw keeps going
Check the blade centre bolt for corrct tightness. If you have fitted a new blade, check to see if it is the type with a removable centre spacer (multi fit type) if it is, it sounds like the centre bolt has bee overtightened at some stage and deformed the spacer which now takes all the drive from the motor instead of the blade itself. Try giving the spacer a light file to remove any burrs. If all else fails, obtain a new blade which doesn't have the center spacer to avoid this problem
Apr 12, 2010 | Ryobi 7 1/4 In. Circular Saw W/ Dual...
Will not cut straight anymore, blade wobbles blade is not old
There are a couple reasons why the blade is wobbling. Either the diamonds are glazed over because the material you are cutting is way to hard or the blade is very thin and when metal gets hot it expands and when you make a longer rip cut it will tend to wobble. I sell blades for a living and i can almost gurantee this is the reason
Dec 15, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Applied dark brown glass tiles and those that were cut with a wet diamand blade saw are darker in colour to the others. will cut tiles become the same colour as other non cut tiles?
THIS COULD BE CAUSED BY 1 OF TWO THINGS, WHEN YOU USE WATER TO CUT ANY TILE YOU ARE INTRODUCING WATER TO THE INSIDE OF THE TILE WHICH WILL CAUSE THIS DARKENING OF THE TILE, 2ND WHEN YOU WET CUT USE A SLOW LITE PRESSURE LET THE BIT DO THE WORK TO MUCH PRESSURE AND NOT ENOUGH WATER WILL CAUSE OVER HEATING AND DARKEN THE TILE. HOPE THIS HELPS. ALSO
THIS DOESN'T ALWAYS WORK BUT AFTER CUTTING PLACE TILE IN A HEATED AREA TO DRY OUT THE WATER ,THE GLAZING IS WHAT PROTECTS THE INSIDE
Dec 01, 2009 | RTO 1/8"wet Diamond Glass, Tile, Stone,...
Diamond blade with diamond center no adapter?
Easiest solution is to get a blade that matches your arbor. It really isn't worth the effort to modify your saw to accept the diamond shape blade you currently have. Most D-I-Y centers and tool shops have what you need.
Nov 20, 2009 | Cars & Trucks
How do you remove the blade on tile cutter model mk470 mk diamond products, inc
Unplug the saw, raise the guard fully, grasp the blade to hold it and loosen the nut then remove the blade.
Sep 12, 2009 | Mk Diamond Products, Inc. 7 In. Wet...
How to repair porcelain/cast iron sink scratches
You can repair the sink with an epoxy based porcelin kit
Epoxy will not show brush streaks it will levelitself out do not get any kits from HD or Lowes they do not harden
Go to Sherwin Williams and ask for an epoxy paint for porcelin
As for removing the under counter sink
I would try cutting through the caulk adhesive
between the bottom of the granite and cast iron
sink with a hack saw blade
I have used a diamond blade on a grinder and
cut through but it was not a granite counter top
Be extremely areful to suport the underside of the sink with 2x4 blocks to prevent stressing the granite as you cut through
Good luck
Dec 31, 2008 | Home
Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Aug 27, 2008 | Mk Diamond Wet Saw with Stand
Dewalt Heavy - Duty 10" Wet Tile Saw - D24000 Logo
32 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
