Question about Krups Orchestro Dialog FNF2 Espresso Machine
Krups fnf2: service 8, what does it mean?
my krups fnf2 tells me this problem: servise 8. what can i do?
  • Anonymous Mar 26, 2014
    serwice 1
On mine, the coffee dispenser had become stuck or clogged with ground coffee. cleaning this and giving it a bit of assistance on the next power up solved the problem. you will need to remove the two TX-15 torx screws at the front under the coffee flap/lid and the water flap/lid. there are also four screws down the back which dont have any screw driver slots in them. you will need a pair of vice grips or similar pliers to undo them. The top then lifts off and you can see down the coffee dispenser enough to clean it out. If you intend to test it with the lid off you will need to tape a magnet on the gray reed switch at the top (to simulate the ground coffee lid being closed). Obviously if you remove the two last screws at the bottom back you can easily remove the sides however in my case this wasn't necessary.
Posted on Mar 08, 2010
  • 1 more comment
  • carelcarel Jul 10, 2011
    Just a litle note to thank your helpful post. mi machine is working again!
  • jmerton
    jmerton Jan 05, 2012
    Quoted $500 to service this. I followed this solution and my machine is like new. Not a difficult task so give it a go! Thanks for the solution.
  • Lachie Wilkinson
    Lachie Wilkinson Jan 30, 2016
    Thanks for this worked well for me.
Hi
my problem is similar but my unit's grinder chute keeps getting stuck and not retracting back into the machine making it impossible for me to reinsert the bottom tray. Any ideas how to reset it or retract the chute manually perhaps?
Posted on Oct 24, 2012
Provide vessel nozzle under
Posted on Aug 16, 2012
I had the same problem and thanks to blacknanna, i fixed it.
Initially my problem was that the FNF2 was saying 'Please container uner steam nozzle and press Hot Water.
when i did that, i could hear the pump but no water was coming out.
I called the service agent who said it may need a service, or simple repair $$$.
I then called the supplier and they said it was a blockage and it would cost $ to fix.
I then tried again and finally got the 'Service 8' error which led me here!
Thanks blacknanna!
Posted on Jun 23, 2010
  • 3 Answers
The Brew Unit needs to be repaired or replaced.
Posted on May 07, 2009
How do I fix my coffe machine?
Contact the authorized service center.
Jan 07, 2016 | Krups Orchestro Dialog FNF2 Espresso...
Krups xp7220 technical error 05
It cannot be an FNF2 and also an XP7220, they are entirely different machines.
Apr 15, 2013 | Krups Orchestro Dialog FNF2 Espresso...
The hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Allan
Dec 30, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Krups XP-7220 Error code 01
Go to krupsusa.com and click on "instructions" they should have the manual to download.
Jan 02, 2009 | Krups Orchestro Dialog FNF2 Espresso...
My Krups iron only heats up slightly. HOw do I repair?
Your question is listed under espresso machines. Are you talking about a Krups Espresso Machine? Please clareify. Does it make Coffee and Steam?
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
My krups coffee machine comes up with service 8, what does this mean
The Brew Unit needs to be repaired or replaced. We repair Krups
Go to www.hotncold.com Click on Jura Repair. Krups and Jura are made by the same company.
May 26, 2008 | Krups Orchestro Dialog FNF2 Espresso...
The krups coffee machine is letting out hot water but not coffee ?
If you find water in the spend grounds drawer or with the cup grid out you see water being dispensed into the drip tray your brew unit needs repair or replacement. If none of that is happening the tube that brings hot water to the brew unit is clogged.
May 24, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Krups Orchestro Dialog coffee machine
that mean no coffee go through us if you dont use the machine often you might have coffee residue on the grinder teet remove the coffee bean in the hole were the coffee bean goes use a brush and clean the grinder teet very good with the residue of coffee gonna grind and gonna go through thanks for usig fixya pierre
Feb 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Krups Orchestro Dialog FNF2 Espresso Machine Logo
4,100 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
