Question about GE 30 in. Profile JP350 Electric Cooktop
Ge JP670002BC cooktop burner always heats at high regardless of what the knob is set at...
3 Suggested Answers
SOURCE: Burner always on high
I have had this same problem on the JP350.
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Posted on Mar 16, 2008
Controlfrk
  • 304 Answers
SOURCE: Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Posted on Aug 31, 2009
Large right/front burner is out of control. Regardless of the setting, the burner heats very high. In fact, recently, oliver oil in a skillet ignited. Even though the control was set to less than medium,...
The switch for the right front burner is defective and needs to be replaced,its bad as far as internally when turned on no matter what its set it the interal contact is stuck on only high so their is no setting it will work on except high. By replacing the switch it will work on the various settings and not just high.
GENE
Sep 23, 2011 | GE Cooktops
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Mar 02, 2009 | GE Cooktops
Tripping breaker
Replace the burner and receptacle and you should be short free. You may also need to replace the surface element switch too if it doesn't come on at all or stays on high regardless off knob setting.
Dec 16, 2008 | Jenn-Air JED8430 Electric Cooktop
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Burner too hot
you set it fro low and goes straigt to high???? no adjustment in heat setting either of or high?? if so youll need to repalce the infinte switch controllins that burner
Mar 11, 2008 | GE 30 in. JP326 Electric Cooktop
Nov 10, 2007 | GE 30 in. JP340 Electric Cooktop
GE 30 in. Profile JP350 Electric Cooktop Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
