Question about LG 32LG30 32 in. LCD HDTV
Remote only works to power on/off
My remote only works to power on/off my tv. I can't access the menu or the input functions. Is there a reset code that i can enter?
Todd
  • 4 Answers
You need a software update for latch up problems.
availble from lg tech guys
and also possible kernal software needed
Posted on Mar 01, 2009
To answer your question...yes. turn the tv off, than unplug it and press the power button for 1minute. this will reset the tv. after 1 minute plug the tv back up and press the power button. good luck!
Posted on Apr 03, 2009
    President:
  • LG Master
  • 1,779 Answers
Take your remote to a local retailer with your brand and try it there, if the remote is ok then depending on the purchase date, return the set would be my best suggestion. Keep me posted?
Posted on Feb 14, 2009
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
How to turn off child lock without remote control jvc lt-32sh6
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
OR
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger.
Nov 01, 2012 | Televison & Video
My ws-55311 shows blue screen on all inputs except the DTV input
This set has 3 hidden menus accessed with a different 4 digit number code----You need the Mitsubishi remote to enter.
One of them is the Option menu which will allow a hard reset of the TV back to factory original---98% of the time it will restore all inputs--cures all sorts of odd problems.
If you have that remote and want to try it let me know for sure the model number and I will give you a link to the instructions for doing it.
Jun 16, 2012 | Mitsubishi WS-55311 55" Rear Projection...
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
[2]
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
We have a KDL-26U2000, the problem is the menu button doesn't bring up the menu?? When you press the button on the remote or the top of the tv the green light will flash so the tv must recognise that I'm...
Checking your remote can be done with any digital camera since they can 'see' the infrared light from them but I suspect the remote is working; generally, if they are emitting anything, it will be sending correct correct pulse trains.
Having the camera 'live' you will be able to see that the remote is working by aiming the remote at the camera's lens and pressing any button while watching the camera's LCD display. The output of the remote will appear as white or near white blinking lights.
> I've tried to reset to factory settings but when I've got into the service menu I can't input anything?
Often the service settings require entering some code (password) sequence to access factory settings and it may not be possible to enter the code if one or the other end of the IR system isn't functioning.
Summary; I think the remote transmitter is OK but the receiver in the set is not decoding the received signal despite it indicating that something was received.
I think the set itself is a fault and you will need a tech on site on in the shop to search for the right board to replace since the IR receiver may be part of the main board (expensive) or a separate assembly (somewhat less expensive).
Jan 01, 2011 | Sony KDL-26U2000 26 in. LCD Television
New remote won't program to switch to cable input.
That's a problem with universal remote controls. Often they don't control every function of the TV. They just don't have the buttons needed to control everything the original remote did. You'll have the most basic controls - power, channel and volume up and down - and maybe a menu button. But you'll frequently find other things don't work, like switching inputs. There isn't anything you can do except try all the codes for your TV brand and see what each button does. You might find that the buttons have different functions depending on which code you've entered. You might also look for another brand of universal remote that has more functions available.
May 23, 2009 | Daewoo Televison & Video
No picture on my television
Found this on the www.toshiba.com website. Q. I have sound and no picture with the TV powered on?
Models: 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL67, 42HL167, 47HL167,
52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00111
Using the buttons on the TV itself (not the remote control), press the “MENU” button to see if the TV’s MENU appears on
the screen. If the MENU does appear on the screen, verify that all of your video connections are secure on the TV and on
the connected device. Double check that you are connected in the appropriate jacks, check the other inputs of the TV to
see if the video appears on any other input. If you still do not see any video but can access the menu, try to reset the TV
to the factory defaults.
1. To reset all settings to default values:
i. Press the “MENU” button on your remote to open the menu.
ii. From the SETUP menu, highlight INSTALLATION and press “ENTER”. A new set of Installation
iii. Open the SYSTEM STATUS menu, highlight SYSTEM INFORMATION and press “ENTER”.
iv. Press the LEFT or RIGHT arrow to scroll through the menu bar to select FACTORY DEFAULTS.
v. Enter your PIN code (or 0000 if no PIN code has been set).
vi. Highlight YES and press “ENTER”. The TV will turn off automatically after a few seconds. After the
vii. If the MENU does not appear on the screen, try resetting the TV by unplugging the power cord for at
least 3 minutes.
viii. If neither of the above steps resolved your problem, you can get assistance with this problem by
contacting our customer solutions department at 1-800-361-3811 Monday through Friday 8am -7pm
CST I hope this helps you with your problem.
Nov 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Still won't work
Hi again,
This forum has much info re Mitsubishi PTVs. Nonetheless, an excerpt from there....
1.Set the Layer Switch at the top of the Mitsubishi Remote to TV.
2.Press and hold the POWER button, and while holding the power button enter 090.
3.Now the remote should function like this:
Power = Power On Discreet
Stop = Power Off Discreet
Pause = AV Reset
Pressing INPUT followed by:
PIP = DTV
1 = Input 1
2 = Input 2
3 = Input 3
4 = Input 4
5 = DVD / Component 1
6 = Component 2
SQV = Input STB
QV = Input VGA
PIP CH Up = Antenna A
PIP CH Down = Antenna B
4.When done, press and hold the POWER button and enter code 000 to return to the standard remote functions
Apr 17, 2008 | Televison & Video
LG 32LG30 32 in. LCD HDTV Logo
262 people viewed this question
Computer Repairing
Computer Repairing
