Question about Goodman GMS90703BXA Heater
I need to know where the filter is and how to change it.
We had a little skunk problem and the house is pretty old. We'd like to know where the filter is and how one would go about changing it.
  • for_puppy_lu Jan 26, 2009
    The unit is in a closet and it's a Goodman heater unit. I will check that and thank you.
  • 82 Answers
Is the unit in a closet, attic, or basement. if the unit is upright it would be in the bottom of the air handler if you can't find a wall return air grill. in the attic it may be in the end of the unit where the return air duct attaches to the unit. if no luck then someone has removed it and failed to install a new one hopes this helps...
Posted on Jan 26, 2009
Broke a bottle of weed spray in the garage. I cleaned n scrubbed it. But can't get rid of the awful smell. What can I do? The smell is stronger when it's raining out
  1. 4 Ways to Get Skunk Smell Out of the House - wikiHow
    www.wikihow.com > ... > Cleaning > Indoor Air Improvement wikiHowHow to Get Skunk Smell Out of the House. Skunk smell can get into your house by a variety of sources. For instance, you or your pet might be sprayed, or a ...
Jul 12, 2015 | Refrigerators
How to poison a skunk
Poisoning A Skunk
Here are types of poison used on skunks:
Anticoagulant (rat poison): Includes warfarin, etc.
Antifreeze (Ethylene glycol)
Bromethalin (a different class of rat poison)
Cholecalciferol
Strychnine
When many people think about killing animal one option that will often come to mind is using poison, but this really isn't a good way to deal with a pest animal. Laying out poison for a skunk can often have unforeseen consequences, and many domestic animals have been killed after getting to a poison that has been laid out for another animal. This is also an inhumane way to kill an animal, and the skunk will often look for a place to hide in safety, which can often lead to people discover a rotting carcass beneath their house or in a cavity in the property.
Be careful where you place it
Sep 30, 2014 | Cars & Trucks
How do I change the oil filter in my 1999 Silverado 1500?
Raise the truck up and support it with stands, then go under the truck and look at the rear of the engine, the filter is just before the transmission bell housing on the drivers side, carefully remove it use an oil filter wrench if it is to tight, have a drain pan under the truck so thai oil won't go all over your pretty clean driveway. Once the old filter is removed take a little motor oil and lubricate the new filter O ring seal with oil and fill the filter about half full of oil, then thread it onto the adapter on the engine, turn it until it just contacts the metal sealing surface of the oil filter adapter on the engine, then tighten it 2/3 more turn. You are done
Sep 13, 2012 | 1999 Chevrolet Silverado 1500
Hi guys do you when changing the oil filter tip the bike over and fput oil in the filter housing before putting new filter in
not usually, the oil pump picks up and gets to pressure pretty quickly. you can do that but some oil will drain away before you get the filter cover back on. at least when the bike is on its side you dont make a mess removing the old filter
Apr 05, 2010 | 2006 KTM 250 SX-F
KitchenAid Superba leaks from filter housing
i would definately change the filter
they are usually only good for 6 mos
or 400 gals
without knowing if its dripping from the housing
i would start with changing the filter and see if that takes care of it
AP3182816
i just checked and thesea re on sale
30.00 is pretty cheap
appliancepartspros.com
i used to sell these off my truck as a maytag guy
for 48
let me knoe
Oct 17, 2009 | KitchenAid Superba Architect KSCS25IN Side...
How do i change the fuel fitler in a 03 power
should have a cover on top of the engine, lift cover , there will be a cylindrical Fuel Filter housing with a lever on the side and a cap on top. remove the cap, remove the old filter & install the new filter & the NEW seals. use the little lever to drain the old fuel & any water from the fitler housing & start engine per normal Diesel starting procedures
Oct 08, 2009 | 2003 Ford F Super Duty Chassis Cab
Oil & filter change
If there is a Auto Zone around your area, you can get the oil and filter there with the step by step  instructions needed to get the job gone. There is a oil filter wrench for you to buy to remove the old oil filter, buy the oil filter cup that attaches to the ratchet, the other wrenches tend to crush the filters. Keep me posted be glad to answer any questions and give you instructions to the oil change procedure if Auto ZOne could not help you or there is not one around you.
Jul 01, 2009 | 2007 Ford Escape Hybrid FWD
Changing fuel filter on 2006 dodge ram 2500 diesel
fuel filter housing on driver side of motor. need the correct size of socket to remove the lid. unscrew lid and pull straight up to remove filter. remove old filter from lid and install new filter and seal. drain old fuel/water from housing. then reinstall filter into housing. tigthten lid then make sure the petcock is closed from draining it earlier. bump the starter a couple times to fill the filter housing then start engine. clean any spilled fuel and your done
Jan 21, 2009 | 2006 Dodge Ram 2500
Car has a skunk like smell and AC question
Listen people...it isn't a skunk! My elantra smells like a skunk too and I am sure I didn't hit one. I think that it might be my battery; since battery acid and skunk smell are chemically the same. This is what I am checking next.
Aug 01, 2008 | 1997 Honda Accord
Goodman GMS90703BXA Heater Logo
51 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
