Question about Ovens
We are replacing a control panel for our Whirlpool double oven
The code that keeps coming up on the screen is E1 F2. What does that mean?
    Scholar:
  • 61 Answers
You don't need a "professional" to solve this problem or even to order any parts. E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem will vanish. if the error ever returns, try pulling out the connector, cleaning the contacts with a pencil eraser (see - http://www.fixyourboard.com/techzone/ovens/keypad_tail_clean/keypad_tail_clean.html - for illustration), reinserting it into the slot and repeat above with the paper. good luck.
Posted on Oct 27, 2010
E1 F2 error code
Check the ribbon cable for connection
Mar 27, 2013 | Whirlpool RBS245PDS Electric Single Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Error code of E1 F2 on a kitchenaid double wall oven. What does that mean?
F2 - E1
Keypad cable unplugged
1.
Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace
keypad (also called touch pad or membrane switch). Some models incorporate
keypad in to control board as one unit. In this case, replace control board
(also called ERC or clock).
Feb 15, 2011 | KitchenAid KEBC207 Electric Double Oven
I just replaced the control board on this whirlpool double oven. It powered up fine but then went to an error code E1 F2. I've double checked all connections and they are fine. Is there a reset...
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch).
Jan 29, 2011 | Whirlpool RBD275PD Electric Double Oven
The top display says F2:E1 and the oven won't function. How do I fix this?
This is not exactly a solution, but it does explain what F2:E1 means. According to this page, it is a control panel malfunction. It may be caused by a shorted wire, but it may just be the control panel malfunctioning on its own.
Nov 04, 2010 | KitchenAid Architect Series KEMC308KSS...
Whirlpool double oven rbd306pdb15 displaying code e6 f2. What does this mean?
HI. This code is in reference to the keys that initiate actions on your unit, The cancel key is malfunctioning at this time. Follow the procedure below to correct the issue.
1. Disassemble the control panel and check the keypad connector for firm connection (keypad connects to the control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate the keypad in to the control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Aug 23, 2010 | Whirlpool Ovens
I have a whirlpool oven rbs305 and the pannel shuts down and a code comes up E6 and F2 What can be done Thanks
F2 and e6 in combination indicate a cancel key open condition. What this means in layman's terms is that the key-panel Has a problem. If it was just recently cleaned with a wet cleaner, you can try drying the keypad off or even CAREFULLY warming it up with a hair dryer. Don't get it too hot so that you melt anything.
If this does not work, you will need to replace the key panel on the oven.
You can do this repair yourself and should you decide to, please just comment back with the full model number off the tag on the oven and I will give you step by step instructions on how to do it.
Good luck!!
Aug 14, 2010 | Whirlpool RBD305PD Electric Double Oven
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Ovens Logo
129 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
