Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile Spectra JGBP85
I have a GE Profile Spectra JGBP85WEB5WW range. I noticed that ever since I used the self cleaning oven feature, my oven does not work right. When trying to use the oven, it seems as though it takes forever to get up to proper oven temperature. The broiler works fine. Tried using the oven again today, after about an hour the temp was only 232. Also, I thought I even smelled gas today, but then the odor went away. Could it be the oven igniter? Any help with this would be appreciated. Thanks
  • 2 more comments
  • Michael McGloin Jul 15, 2007
    Do you happen to know where the igniter is located?
  • Michael McGloin Aug 11, 2007
    Yesterday, my husband put in a new oven igniter. Thought this might have solved the problem. It still takes about 30-40 minutes before the oven gets up to 350 degrees. My mom has the same stove, so I went over to her house today and set the oven to 350 and within 9 minutes it had reached temperature. Any thoughts as to what might be the problem.
  • Michael McGloin Jul 29, 2008
    The last time I posted was in August, 2007. The problem still persists with my GE Profile Spectra JGBP85WEB5WW. My husband replaced the oven igniter back in August, 2007. The broiler ignites and works well. It seems as though the problem with my oven really hasn't been fixed. When I turn on the oven, it seems to take forever to reach proper temperature. On rare occassions, my oven seems to reach the desired temperature in about 15 minutes compared to the 25 - 30 minutes it usually takes. Sometimes, I even smell gas. When I went to use my oven last night, I turned it on and proceeded to do other things around the house. When I got back into the kitchen, it really smelled of gas. I turned the oven off and tried my broiler. The broiler started right up. I kept the broiler on for about 5 - 10 minutes and turned it off and then set the oven to 350. It only registered to 242 degrees and would not increase in temp. So I kept alternating by turning on the broiler and then the oven to try to finish cooking my dinner. At one point the oven did reach 350 degrees. This went on for about 1 1/2 hours and still my dinner was not completely cooked. It was hot but not hot enough to melt the cheese in my lasagna. I don't know what to do any more. My husband insists on fixing the problem himself, but doesn't know where to start. Some one said it might be the gas valve. If so, where would the gas valve be located on the appliance.
    When I used my oven a couple of days ago to bake a cake, it did reach the desired temperature but it took some time before it got to the desired temp. And it took a lot longer for my cake to bake.
    Any help anyone can give would be greatly appreciated.
    Thanks.
  • kolbrat Oct 01, 2008
    I have a frigaire gallery professional series and i used the self cleaning and now my oven an broiler will not work
  • 5,911 Answers
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
Posted on Jul 15, 2007
  • Jeff Rockwell
    Jeff Rockwell Jul 15, 2007
    Just be careful when handling the igniter. Try not to touch the element portion. Oils from your hands can shorten the life of them.
  • Jeff Rockwell
    Jeff Rockwell Jul 16, 2007
    The igniter should be under the bottom pan in the oven. There will be a couple of screws in the back to take out, first, then the pan should lift out. Under the pan is a heat deflector that is mounted right over the burner assembly. If you remove the deflector the igniter will be visible next to the burner assembly in the rear. There should only be a couple of screws holding it on (remember how you took it off, so you can reinstall it) and a wire connector. Make sure you unplug the oven or turn off the circuit breaker first! Sometimes the wires are spliced. Good luck and let me know if this helps.
SOURCE:
Lost manual for model # jgsp31ger3wg, GE Profile gas range. want to clean oven...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 11, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you lock the oven to clean? GE Spectra Profile Glass Top Stove
Before you try and use the self cleaninf feature... save your self some more problems by reading this tip that I wrote...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 04, 2010 | GE Spectra JBP78 Electric Kitchen Range
How do you use the self clening feature of the oven
Why would you want to use the self clean feature in today fickle electronics? The 900 f degree temp melts the delicates in the controls. OOPZ
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I started the GE self cleaning feature on my GE
It will stop when it is done cleaning, usually about 3 hours.
Jun 07, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Don't know how to start the self cleaning oven. Please advise.
Most service techs will advise you not to use self clean features on a oven due to excessive parts failures from the extreme heat.
Feb 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I don't remember how to use the self cleaning feature
Remove everything from the inside of the oven, lock the door if your model has a latch handle that you move from left to right to lock the door, then set the oven selector switch to clean.
Dec 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JGBP85
Try this: turn off the circuit breaker to the oven. You are looking for a pair of breakers generally rated 40 amperes or more. Turn them off, wait a minute and turn them on. If that doesn't do it, then there may be a circuit board issue.
Nov 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP85WEB5WW Range
It sounds as if you might have a problem with the gas valve for the oven. This is something that I would not reccomend that you try and fix yourself.
Aug 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
728 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Kitchen Range Expert? Answer questions, earn points and help others
