Question about Western Digital My Book Home Edition 500 GB USB Hard Drive
Usb port prongs are bent
My 500GB WD external hard drive prongs are bent and my computer will not recognize the HD anymore. I hope it can be replaced!!!!
  • 341 Answers
SOURCE: Flashing light on WD 500GB External Harddrive
This may sound silly,but sometimes if you put the drive in the freezer overnight it will work long enough for you to retrieve your data.Make sure you are ready to copy the data to another as it will likely fail again once it warms up.
Posted on Nov 26, 2008
SOURCE: My I Mac doesn't recognize the WD 500GB external drive anymore
it must be initialised /mounted 1st for osx
Posted on Mar 08, 2009
Suricatta
  • 92 Answers
SOURCE: WD External Drive-USB recognize, but no icon, can't access
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Posted on Jun 24, 2009
greg_margo
  • 1959 Answers
SOURCE: cannot transfer files that are greater than 4GB
The lack of free space iis on your internal HD not the external. Whenever transferring files from one drive to another, you are acturally making a copy of the file to be transferred and sending the copy to the new drive. If your internal HD is nearly full, you can try to Cut and Paste the files to the external, or clear up more space on your internal b/4 tryiing to move the bigger files. Best of luck.
Greg
Posted on Jul 09, 2009
bob_computer
  • 3153 Answers
SOURCE: my mac won't recognize my wd hd anymore
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Posted on Aug 31, 2009
I bought the Western Digital Elements External hard drive-500GB and it worked fine with my computer. I took it to my brother's house to download some data and his computer DOES NOT RECOGNIZE it when it's...
HI, YOU MAY WANT TO TRY, REMOVE SECURITY FROM WITHIN THE SMARTWARE, THEN AND AS ALWAYS, MAKE SURE THAT THE DRIVE, WHEN BEING CONNECTED/DISCONNECTED, THAT THE PC IS COMPLETELY SHUTDOWN.............. I HOPE THIS HELPS.........JEFFXC
Jan 25, 2011 | Western Digital Elements powered by WD 320...
The prongs on my external hard drive are bent and my lap top is not recognizing the drive when plugged in. Can I just replace this port?
Yes you can replace the port, of you can see what hard drive is in the drive and get a new external holder/card for it and use it that way. either 2.5 inch sata or 3.5 inch sata,
Jan 19, 2011 | Iomega 500GB eGo Helium Portable 500 GB...
Hd will not read and puts up error code 43
I had the same problem with a WD external hard drive. I tried it in multiple computers and it was never recognized. I uninstalled the driver from the same screen where you see the error 43 message, then swapped the USB cable connecting the drive... and then the computer detected it. It suggested a chkdsk which I ran, it looks like its back to normal now
Nov 25, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
My mac won't recognize my wd hd anymore
Aug 31, 2009 | Western Digital My Book Essential 500GB...
My iomega 500gb external hd isn't being recognized. There's an icon for safely removing hardware but under the 'my computer' tab there's no icon for the drive, as though its not even there. It had been...
Did you have to install a driver for it initially? Try reinstalling the driver, if so.
I thought most drives were plug and play. If it does not have a driver, trying using a different USB port. Sometimes the ports can freak out and not recognize the item plugged in, especially if you use multiple items in the same port. (ie, cameras, cell phones, printers, etc)
Hope this helps at least some. Good luck!
Jul 31, 2009 | Iomega 500GB Ultramax HD USB 2.0/FW 500 GB...
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
Western Digital My Book Home Edition 500 GB USB Hard Drive Logo
340 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
