Question about ASM G Skimmers ASM Mini G Protein Skimmer
Manual for asm mini G protein skimmer - ASM G Skimmers ASM Mini G Protein Skimmer
Can I use OZONE in my Euro-reef protein skimmer?
Absolutely, all Euro-Reef protein skimmers are safe for use with ozone.
Aug 30, 2012 | A H Fabrications Fish
Can I use protein skimmer on fresh water aquariums?
Protein skimmers only work in fresh water under very high pressure and on salt water aquariums.
What maintenance does a protein skimmer require?
Protein skimmers that use a water pump need to have their pump serviced regularly. You will also have to clean the collection cup from you skimmer on a regular basis. Depending on your tank load you may need to do it as often as once a day or once a month.
What is a protein skimmer?
A protein skimmer is a device which removes organics in your tank by way of mass air bubbles. When the water passes through the skimmer, the air bubbles it produces allows the chemical compounds of organics to attach to the bubbles and ride to the surface where the gunk is collected.
What is a prism protein skimmer?
The prism protein skimmer uses both Co-Current and Counter-Current water flow. It uses a turbo-jet impeller which creates constant stream of micro-bubbles.
What is a Co-Current protein skimmer?
Co-current protein skimmer is one of the methods used in aquarium water skimmers. The air source is on the bottom of the reaction tube. Water is drawn up into the chamber with minimum dwell time. This skimmer is the least efficient of all skimmer designs.
What are the top skimmers picks?
The five most recommended aquarium skimmers are: Aqua Medic Turboflotor 1000 blue hang-on skimmer, Aqua C Remora protein skimmer, AquaticLife internal mini skimmer 115, Eshopps hang-on tank protein skimmer and the Lee's Counter Current protein skimmer. Each has its own benefit.
What's a protein skimmer?
A protein skimmer removes organics in your tank by way of mass air bubbles. When the water passes through the skimmer, the air bubbles it produces allows the chemical compounds of organics to attach to the bubbles and ride to the surface where this gunk is collected in a cup and you should dispose it.
Aug 02, 2012 | Fish
I just bought a protein skimmer for my aquarium but it didn't come with a manual. Is it easy to set up?
There are number of complicated steps that go in to settingup a skimmer. Because it is such a heavyand often expensive piece of equipment, I recommend that you only install itpersonally if you have prior experience. If not, I suggest contacting a professional to do it for you. If you think you are up to the challenge, please see thisYouTube video with step by step instructions:http://www.youtube.com/watch?v=MLAgZopwyDM
May 13, 2012 | Fish
ASM G Skimmers ASM Mini G Protein Skimmer Logo
170 people viewed this question
Top ASM G Skimmers Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you an ASM G Skimmers Fish Expert? Answer questions, earn points and help others
