Question about Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312
Need a manual for kenmore chest freezer, how to defrost
Model 253160502100 kenmore chest freezer how to defrost freezer
bobotfel
  • 236 Answers
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Posted on Dec 28, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
dauphine
  • 207 Answers
SOURCE: Kenmore Chest Freezer
It might be freezing normally but that doesn't mean that compressor's motor isn't overheating due to lack of freon or mechanical problems on motor itself. Better not risk a fire and let someone experienced check the compressor's motor. Overheating is never a good sign.
Posted on Apr 20, 2008
  • 3 Answers
SOURCE: Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Posted on Nov 21, 2008
  • 68 Answers
SOURCE: my kenmore freezer does not turn on at all
u either need a new thermostat or your compressor is dead
Posted on May 02, 2009
Does the kenmore cold spot chest freeze model 253.8193610 have a defrost timer
Chest freezers don't normally self defrost. They just freeze. To defrost them, you must shut them off.
May 02, 2010 | Kenmore Freezers
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
General electric 5.0 chest freezer has water coming all over the floor.
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor. A new defrost timer should be available from the local refrigeration wholesalers in your area.
May 11, 2009 | General Electric Chest Freezer FCM5SU
Nov 19, 2008 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Kenmore manual upright freezer
we got alot of ice chest and cleaned out the ice. this fixed the problem so far. we dint lose any food thank goodness.
Jul 07, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312 Logo
64 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
