Question about Denon AVR-1500
Proper hook-up from Denon AVR-1500 receiver to muti speaker box
HELP!!!! I unhooked my stereo to move it and now don't remember where the wires go from the muti-speaker control box to the receiver. I have all the speaker wires connected but must have the proper wires to the receiver wrong. I looked in the manual but it doesn't speak to a "muti speaker box".
  • 119 Answers
Ok, All the spkrs from around the house get pluggeg into the spkr selector box out to spkrs and on the back of the Denon plug wires to connect the spkrs A to the spkr box and that should take care iof that for you
Posted on Feb 25, 2009
How do I hook up my bose 901s to this unit?
Well the basic connection of the speakers would be the same as another stereo speaker pair. Wire the left and right speakers to the L/R Front Surround speakers on the Denon.
With the 901's I am assuming that there is an external equalizer supplied by Bose. Typically this EQ is installed in a tape loop on the receiver/amp so that it is ahead of the power amplifier that drives the speakers. This EQ needs to be there to attempt to get reasonable frequency response from a speaker that has only 4" drivers. I'm not sure I see any reasonable way to make the EQ work with the Denon AV receiver. You'd likely be better off using the Bose speakers in a dedicated 2-channel stereo and getting a set of speakers for the AV usage.
Apr 16, 2016 | Denon Avr 3805 7.1 Channel Audio Video...
How do i connect my television to my receiver
go here to get the manual Denon and then the docs tab
Mar 07, 2014 | Denon AVR-485 Receiver
I was re-wiring my surround speakers to my Denon AVR 1803 while playing soft IPOD music through it so I could correctly identify each speaker and hook it to the right jacks on the rear. Suddenly in...
A shorted wire would do it. Take it to a tech and tell him what happened. If you remember which channel you were handling at the time it might help hum to find the problem.
Dec 23, 2010 | Denon AVR-883 Receiver
I have a Denon AVR 3805 receiver. It does not have a Main Amp in or a pre Amp out in the back. How do I properly hook up the Bose 901 equalizer to this receiver? I use the 901 speakers as surround...
By properly, you must mean WITH the Active EQ.
According to this picture, you're in luck BUT...
http://www.audioholics.com/reviews/receivers/denon-avr-3805/denon_AVR3805_rear_lg.jpg
(Short answer from personal experience.)
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers. A good 100-wpc amp will do. (I like Carver)
Connect the Active EQ between the Front pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Oct 14, 2010 | Bose 901 VI Main / Stereo Speaker
I hv a Denon AVR 3805, i tried to set it up but after doing all the necessary, i found out that it was only running on 3 speakers (FL,FR & SW). I did connect the center speaker but the sound just...
SW means sub woofer, not necessary means center speaker in all receivers. Instead of setting 5ch stereo, if you have 3 speakers. try to set "3channel" or "simulated". If you own more than 3 speakers, you may refer to the user´s manual to correctly wire them to get the full sound.
Sep 18, 2010 | Denon AVR-3805 Receiver
Denon AVR-1604 too large front speakers blew the avr
Try disconnecting the speakers at the receiver. turn it on radio or any other source and turn up the volume. If the receiver still shuts of, there is an internal capacitor issue and needs serviced. More than likely though, it's a speaker problem. If the speakers were underpowered and at max volume, chances are the damage was to a voice coil in one of the speakers. If the receiver continues to stay on without being connected it's ok. check your speaker wires as well. Frequently loose braids on wires touch each other and create very little resistance until turned up, more volume, more resistance. Then the receiver puts itself into protection mode so no damage will occur. If you need further help, post a comment and I can help you troubleshoot further.
Aug 17, 2009 | Denon AVR-1604 Receiver
5ch/7ch stereo in 5 channel mode
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
Feb 22, 2009 | Denon AVR-2105 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Audio troubleshooting with an AVR Denon 900
ok i have the same reciver do you use hdmi to go to your tv or componet what ever you use there will be an audio out for rca on the cable box if you dont use a cable box keep reading but use hdmi to tcv then the rca audio out to the denon avr 900 obviously out it in the vdp/tv unput. and if you dont use a cable box your tv shoiuld have an audio output in the back of it for rca connect rca to audio output then other end to the denon avr 900s vdp/tv input
Dec 27, 2008 | Denon AVR-900 Receiver
Denon AVR-2106 troubles
If the surround back is turned on,on the receiver,then the 7CH stereo will activate the 2 rear,but if it's off on the receiver the 5CH on the remote will do the same. I don't know much about the unit changing from 7CH to game,rock Arena etc.that i know will happen if u press the DSP simulation found @ the 3rd. top right button on the remote.
Jan 16, 2007 | Denon AVR-2106 Receiver
268 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
