Dryer has power and functions but will not heat. Checked all modes with same result.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the blower motor to make sure it is not faulty, also check the blower fan blade to make sure it is not broken or plugged with lint.
Check the Door Switch.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It's located on the blower housing.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Jan 15, 2011 |
Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer, Whirlpool,LEN2000KQ1,has power, but would not start, so replaced the door switch and the dryer worked for a few minutes when it finished the cycle it wouldn't start again. Is there any other start switch on the dryer That I can check?
Thank you, Denise
GE electric dryer just stopped working. The door light works. A couple weeks ago the timer went out & I wonder if the dryer was left on high heat & forgotten about & the motor burned out. Any suggestions?
joel
granpyoel@hotmail.com
dryer was working perfect, took last load of clothes out of dryer and now it wont start
Dryer will not start. Checked the breaker switch and that was not the problem. It was working yesterday, but will not start today. Any suggestions? Thank you.
Mine has the same problem, and does hum when you set the timer with no need to hit the start button. Any suggestions? We think it is the start capcitor.
I do not have the same model number but I do have a Roper dryer division of whirlpool. My Roper dryer wont start, it worked fine yesterday. When pressing the start switch I get no hum or buzz acts like its unplugged. I have checked the breakers OK, checked for 240 at the outlet OK, and I have 240 at power cord block on dryer also checked for 120 at neutral and ground all is OK,checked dryer door switch it ohms and has 120 going to it, the start switch ohms at the two blue wires with a flicker of ohms at the pink and black wire, there is 120 at the blue wire going to the start switch after pressing the switch power passes through to the other blue wire, just a flicker of voltage momentarily at the pink and black wire, Checked thermal fuses and get ohms. Not sure what to check next.
