Question about Water Heaters
Braeburn thermostat need to reset
Stuck on 80 degress will not reset or change temparature
Changed the batteries in timer/thermostat but the boiler is still not talking to the transmitter heating still on can you help??
Is this a wireless system, meaning no wires between the thermostat and the boiler? If so, check to see if the code buttons have been reset. If this is a hardwire system, the relay on your control board may be stuck. In any case, you can always shut off the boiler by turning off the gas and/or circuit breakers.
May 31, 2016 | Water Heaters
Where can I find reset button and is there only one reset button
http://www.marathonheaters.com/useandcareguide.pdf Upper thermostat has only reset button.
Jul 31, 2014 | Marathon Lower Thermostat - Standard -...
Reset button will not reset, stuck in place
Best solution would be to change out the thermostat it could cause problems if by chance you do get it to reset. Something goes wrong and it want trip the reset it could cause a fire, so the safe thing to do change it out.
Oct 23, 2011 | RELIANCE ELECTRIC WATER HEATER
Temparature and pressure relief valve seem to be leaking continuously
1) Lift TP lever and lower back down to dislodge anything stuck in valve
2) Replace TP valve with generic one from hardware store
Steps for replacing valve are shown on link below
http://waterheatertimer.org/How-to-replace-TP-valve.html
Jan 11, 2011 | General Electric GE SmartWater Household...
Reset button keeps tripping, water gets too hot,new elements did not solve problem, can it be fixed or does the water heater need to be replaced?
replace the thermostats, be very careful!!!! thats 220volts for elec water heaters, 220volts kills you if you touch it wrong,.....it is one thermostat but it's best to match them, so you'll need both,...not expensive. good luck, cracklin joe
Jan 07, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Baxi 80 overheating on hot water circuit
thermostat on the gas valve needs to be replaced,, which you will probly have to change the hole gas vale ,, check on the parts and labor and if it is over 6 years old wheigh the diffrence between it and a new unit good luck
Jun 10, 2009 | Water Heaters
York Dianond 80 Furnace
You have a limit switch that needs to be reset. It is probably the roll out switch that is located on the burner housing. The limit switch is a disk about the size of a dime or penny and has two wires to it. There is a small button in the middle of these two wires. Press this button firmly to reset it. Look for all the limits that may be on the unit that is manual reset like the one described above and do the same. This should correct your problem.
Apr 12, 2009 | Water Heaters
Rheem Hot Water Cylider Thermostat keeps tripping
Sounds like you have a faulty thermostat.  This is the unit that detects the water temperature, and if it is not where it is set, will kick the switch to allow electricity to flow to the elements you replaced. The thermostats are relatively cheap and if you have the knowledge to change the elements, changing these thermostats should not be a problem.
Mar 07, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
