Question about Sony BDP-BX2 Blu-Ray Player
New Blu Rays won't play on my Sony Blu Ray Player (BDP-BX2 model). One disc says I may need a firmware or software update.
Unit says can't play disc on three Blu Rays I recently bought. Says I may need a firmware or software update. What do I do?
  • Robert Neely Jan 20, 2013
    Never mind. I have to bring my BluRay player in to Best Buy and they will download the required software You showed a comment from someone with the same problem, why didn't you know the answer by now?
  • 98 Answers
SOURCE: Sony BDP-S300 won't play any Blu Ray discs
Sounds like a defective Drive
Posted on Feb 06, 2009
  • 1606 Answers
SOURCE: My Sony Blu Ray player BDP BX1 won't play any
I assume you tried the software update after the unit failed. If it quit working because of the firmware update, you may have received a corrupted file. In that case, try downloading a new copy on a different computer or to different media, and repeat the update.
If (assuming hardware problems and not bad firmware) it cannot play any optical disk, not even audio or photo CDs, I would suspect the laser in the optical drive has gone bad. Replacement is not a lot of work, but the part is probably about $50. I think it's likely this is the same part used in the Sony Playstation 3, which had some problems with lasers dying too soon when it first came out.
Here's a way to check: first, insert a DVD in the player. Unplug it and remove the top cover. Caution: do not tip the player with the DVD inside. CAUTION. Directly viewing the laser can cause severe damage to your vision. DO NOT put your face over the DVD drive - ever - while it is plugged in. Observe it from the front, a little off to one side. Before plugging in, check the ceiling overhead and make sure there are no mirror-finish or glassy reflecting objects above the player. The DVD must be in first for safety reasons; it covers the laser. The rest is additional precaution.
Now, plug in and turn on the player. In normal operation, the laser comes on, and the lens moves up and down to focus on the disk. You may see a blue glow in the center of the disk (especially in a dark room). If the laser is working and the laser/lens assembly is able to obtain a focus, the disk will start spinning. If the disk does not spin, the laser/lens assembly is the first suspect. It is also possible that the spindle motor drive is bad, but given the history of PS3 Blu-Ray drives...
If there is no movement of the lens assembly, check the power supply. If it is good, there is (by elimination) another problem with the lens assembly (controller problems, to the best of my knowledge, are rare). Because it has very tight assembly tolerances, the lens assembly is usually replaced as a unit rather than repaired in the field.
Posted on Oct 17, 2010
SOURCE: sony BDP-BX2 Blu Ray player won't read disc. Do i
The latest update version is .008. Yes, you most likely need to do this. I have done two update so far. Ver. .006 and .008. Both times this solved my disc problem. On one of my disc for the newest version, I put the disc in and it could not read it. I was really surprise and put in back in again and it played. I've come to the conclusion that many disc pressing are not very good and some of the Blu-ray players are more finicky about reading that bad pressing. Exchanging the disc for another sometimes works.
Posted on Jan 22, 2011
muntejaya
  • 10421 Answers
SOURCE: I need to unlock the region code on my Sony
Hi, kindly get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__cd45r21
Posted on Feb 27, 2011
shajanrs
  • 890 Answers
SOURCE: I have a BDP S-350
I'm sorry for the difficulties you're experiencing in playing the new Blu-ray disc in the Sony Blu-ray Player.
In most cases, the issue might be with the Java content on the new Blu-ray discs is making these issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is).
Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6385&os_id=99&mdl=BDPS350
I'm sure, installing the firmware update should resolve the issue. If you need any further clarification/assistance, please let me know.
Thanks for understanding.
Posted on Jun 11, 2011
Why won't it stream or play disk?
Call Kurtis: Why Your Samsung Blu-ray Player May Not Play ...
sacramento.cbslocal.com/.../call-kurtis-why-your-samsung-blu-ray...
KOVRSep 26, 2013 - Blu-ray players aren't the same as DVD players. ... disc compatibility issues arise and firmware updates for our Blu-ray players are ... My BD-C6500 is apparently one of those old blu rays that won't play blu rays. ... If you are viewing netflix streaming thru your samsung bluray then YES it definitely can. Its not ...
play mp4 files on a blu-ray player - MP4 - Streaming Video ...
www.tomsguide.com/answers/id.../play-mp4-files-blu-ray-player.html
Jan 9, 2014 - I see a lot of Bluray players will play mp4 files. ... If it won't do it via the USB port, will it do it if the mp4 files are on a DVD? ... player has a menu, items likeDisc Tray, Netflix (I use this menu choice to watch streaming Netflix), ...
Sony BDP-S590 3D Blu-ray Disc Player with Wi-Fi (Black)
www.amazon.com/...Blu-ray-Player.../B006U1YUZE
Amazon.com, Inc.Sony BDPS790 4K Upscaling 3D Wi-Fi Blu-ray Disc Player. 4.0 out of 5 stars 334 ยท Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player .... With the Sony BDP-S590, you can wirelessly stream music throughout the home to .... at internet.sony.tv as in the past some Sony products won't connect to certain services ...
Amazon.com: Sony BDP-S5100 3D Blu-ray Disc Player with ...
Jan 07, 2016 | Televison & Video
Sony BDP-BX2 Blu-Ray player now rejects valid discs as "invalid"
Sometimes the latest update IS the problem, not the solution. If possible go back to an earlier version and retry the disks. Many of the answers here about power down and the like are all good and sometimes helpful things to do. They also point to the fact there isn't much a consumer can do to fix or repair malfunctioning DVD/Blu-Ray players and it always comes down to cost. Do you want to repair or replace. You've had your unit, you say, about 3 years? I think this is about end of life. Anyway, try the previous software version and if that works turn automatic update off.
Nov 14, 2013 | Sony BDP-BX2 Blu-Ray Player
My Sony Blu-ray BDP-S300 will not read blu-ray disc.
You need to update your software. go to network update but you have to do it via your network it worked for me. Hope this helps
Sep 24, 2012 | Sony BDP-S300 Blu-Ray Disc Player
I have a three year old SONY Blu Ray BDP-s350. I bought a new blu-ray dvd. When I try to play it, just initial picture with title is looping. No menu appears. My old dvds play well. I checked this new dvd...
I'm sorry for the difficulties you're experiencing in playing the new Blu-ray disc in the Sony Blu-ray Player. In most cases, the issue might be with the Java content on the new Blu-ray discs is making these issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Jun 11, 2011 | Sony BDP-S350 Blu-Ray Player
I have a BDP S-350 blu-ray player that just started having a problem playing a couple of blu-ray discs that I get from Netflix. The disc will load and start then will stop playing after about 10 seconds....
Jun 01, 2011 | Sony BDP-S350 Blu-Ray Player
I have the Sony BDP-BX2 version 006. My last 8 Blu-ray disc I purchased, 3 would not read. Took all back and exchanged for another (same movies) and only one was able to play. Is this an upgrade...
hi,
may be of upgrading problem or all blue ray disc won't play in all players. if a blue ray plays on a blue ray player may will not work in another one and vise versa. not all the discs some one.
ok
Dec 31, 2010 | Sony BDP-BX2 Blu-Ray Player
I have the latest software version for the BDPBX2 11.4.008 when I try to play the Avatar Bluray DVD I get the following message: if you experience problems playing back this DVD go to...
I have Avatar Blu-ray movie and it plays on my BDP-BX2 11.4.006 version. Take it back and get it exchanged. Try new one. May have to go to another store since the same shipments (bulk) that are at your store are ALL the same. I have done this 4 times with 4 different movies and 2 of them worked. I'm getting the .008 update but, I'm starting to think the Blu-ray disc are the problem since I have one that is made in Mexico??? I don't think they are all being made correctly. Too Cheap!
Nov 07, 2010 | Sony BDP-BX2 Blu-Ray Player
Sony BDP-BX2 Blu Ray player won't read disc. Do i need to update the firm ware? or something?
Sep 20, 2010 | Sony BDP-BX2 Blu-Ray Player
Will not play new disc
Needs a firmware upgrade. See other posts of same problem.
Dec 28, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Sony BDP-BX2 Blu-Ray Player Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
