Question about Black & Decker 16Inch Hedge Trimmer
B & d tr 165 white wire contact on motor is? - Black & Decker 16Inch Hedge Trimmer
THE SCANNER SHOWS p0 708
code p0708 refers to transmission range (TR) switch/sensor--high input===causes --wiring short to positive--TR switch/ sensor--ECM/TCM
replace the TR sensor /switch first and then check the TCM for operation
Aug 14, 2014 | Cars & Trucks
Un plugged the wires from the switch and do not remember how it was wired up. I have three white wires and one black. One white and black wire is coming from the power cord the other two white wires are...
Mmmm... that's a little more complicated. If you have a continuity / resistance meter, we can noodle it out, though.
First, are the two white wires the ONLY wires coming from the motor? I suspect they are - that's not in conformance with any accepted color code, but it'll work. For the rest of this, I'll assume that the two white wires are the only ones from the motor.
You'll need to meter the switch itself, with no wires connected to it. In the OFF position, you shouldn't find continuity between any of the four switch contacts. In the ON position, you should find continuity between two pairs of contacts.
The black wire from the power cord should go to ONE of the two switch contacts in a pair that have continuity with the switch turned ON. One (either) of the white wires from the motor should go to the other switch contact IN THAT PAIR.
That leaves you with one more pair that has continuity with the switch turned ON. The white wire from the power cord goes to one of those, and the second white wire from the motor goes to the other one.
When you have it all wired up, plug it in & turn it on. If it's not right, it should immediately pop your circuit breaker. If it IS right, it should run fine.
If it pops your circuit breaker, open it back up and swap one wire from the power cord and one wire from the motor.
Jun 24, 2014 | Grinders
Need wiring schematic for ametek 119550
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Dec 13, 2012 | Vacuums
TR274 & TR 291 Wiring Diagrams
Copy following link for specific wiring diagrams for combo switches:
http://waterheatertimer.org/How-to-wire-switches.html#combo2
Combo switches require Neutral wire in the box.
Neutral wires are usually the white wires twisted together, covered with wire nut, and pushed to back of box.
Nov 09, 2012 | Cooper Wiring Devices Triple Deco Single...
I have a marathon 3hp motor wired for 220 on a campbell hausfield air compressor. It has a white, black, and green wire coming out of the motor. I am using a no. 12 wire with ground. how do i wire it up to...
Hi! sims146
The Green wire from the electric motor is ground. Check the compressor motor, make sure it is wired for 220-230 Volts. If it has a white wire it could be wired 120 Volts. There should be voltage and current ratings on the motor plate. I always double check these connections. At 230 Volts this motor should be 17 Amps full Load. A 25-30 amp fuses are required to protect this motor circuit. Otherwise up to a 42.5 Amp Inverse Time Delay Breaker could be used.
The welder circuit should have 230 Volts between the Red and Black wires. The white wire is Nutral / Ground. Hopefully this is a 30 to 40 Amp circuit. The Four prong air compressor outlet, White is Neutral, Black and Red 230 Volts, Gray should be ground. Please check with Voltmeter, as some times people swap colors.
InMrFixIt
Jun 25, 2011 | Garden
How dou you connect the electical wires I connected them and it throws the breaker
Look at rating plate on motor.
Look for volts, watts, amps.
Figure with Volts x Amps = Watts.
Amps = Watts divided by Volts
1 hp horsepower is 756 Watts.
Lets say you have 120Volt 2hp motor
So 2 horsepower motor draws 1500 Watts
Amps = 1500 Watts divided by 120Volts = 12.5 amps = so you need 120Volt 15 amp breaker with at least 14gauge wire (as long as motor is located within 50 feet of breaker.)
If motor is farther away, then you need 20 amp breaker with 12gauge wire.
Look at circuit breaker rating.
If motor is 240 and breaker is 120, then it will trip breaker.
If motor is 120 and breaker is 240, then it will trip breaker.
If breaker is for 15 amps and motor draws 20 amps then it will trip breaker.
Generally speaking, if motor and breaker are 120V, then black wire goes to black wire; white wire goes to white wire and green wire connects to bare copper wire.
If motor and breaker are 240V, then wire colors can be different. Black-red or Black-white from breaker connect to Black-red or Black-white at motor.
Add a comment. Say the motor rating and color of motor wires. Say the breaker size and color of wires coming from breaker and I will help you wire the device.
Nov 27, 2010 | Northern Industrial Tools Electric Meat...
Which wire is accessories in a tr magna... i need 2 hook up amp
if you have an aftermarket radio it will usually be the blue wire with a white strip (that is the amp turn on wire). If you hooking it up to a factory head unit, just test the wires behind the radio when you turn the key the wire should through a (+) and when the key is off it should be negative (-)
Apr 29, 2010 | Car Audio & Video
Wiring My Pool Pump
that pump is probably prewired for 220volts. you will have to check the diagram for how to configure it to 110v. most motor can be converted to 110v. If you are not comfortable with reconfiguring, contact a service tech.
Sep 13, 2009 | Dynamo ABOVEGROUND POOL PUMP - 3/4HP -
E511 error code
  1. Check of Photoconductor Unit attachment. Re-attach Photoconductor Unit.
  2. Is the Drum of Photoconductor Unit rotating?
  3. Remove Photoconductor Unit. Turn gear of Photoconductor Unit until silver seal attached to Belt can be seen.Is silver seal dirty?
  4. Remove Photoconductor Unit. Is SENSOR TR-0 attached securely?
  5. Remove Photoconductor Unit. Are there any dirt or foreign bodies on the SENSOR TR-0 surface?
  6. Does the error recur when the power is turned ON?
  7. Remove Photoconductor Unit. The voltage of P416-2 ↔ P416-3 on PWBA MCU is 5 VDC when silver paper or other reflective object comes close to the sensing area of SENSOR TR-0, and is 0 VDC when the object is released?
  8. The voltage of P416-1 ↔ P416-3 on PWBA MCU is 5 VDC?
  9. Disconnect the P/J416 from PWBA MCU. Do all of the wiring below have normal continuity?
  10. Replace MOTOR ASSY P/R.
Jun 19, 2009 | Epson Aculaser C1100 Printer
Rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Black & Decker 16Inch Hedge Trimmer Logo
22 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
