Question about GE Refrigerators
How do you disable the door alarm on ge refrigerator
I have a GE Profile Series PYE22PSHSS 22.1 cu. ft. Counter-Depth French-Door Fridge. The door adjar alarm used to sound off a chime (which I turned on and set to high in the settings). It has suddenly...
Hey I get it understand what you're asking about the alarm can be disabled by pressing a sequence of buttons at the push-button controls on the front of the fridge I don't know exactly which ones they are but if you look for the alarm it'll be written sideways and small near the normal button
Mar 07, 2018 | GE Refrigerators
Refrigerator door alarm won't go off
Attached is link to users manual.
Manual says that Door Alarm will sound if any door is open for more that 2 seconds and will ssop when door is closed.
Can you locate the door switches?
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60530-2.pdf
Aug 20, 2014 | Star Manufacturing GE Profile PFSS5PJX...
High-pitched alarm-like sound coming from GE frig - TBX22PRYCRAA
Very common problem is the evap fan located in the freezer section is the cause. Sorry but this is controlled by the main board on the back and only way to fix the problem is with a new board. Sorry about the news but it is the problem.
May 31, 2010 | GE PFS22SISSS Stainless Steel French Door...
Disabling the door alarm.
Tape the door open buttons down. It's dark but quiet. Same problem with my dogs and a Bosch.
Dec 02, 2009 | Kenmore TRIO 77314 Side by Side Bottom...
Alarm
The door alarm beeps constantly on my GE Prof Arct. The filter light is blinking when it beeps, but I do not have it hooked up to water. Is there anything I can do to stop it?
Aug 22, 2008 | GE J Series 18.2 cu. ft. Top Freezer...
GE Side by Side Refrigerator
Door Alarm -
To set the alarm, press this pad until the indicator light comes on.
This alarm will sound if either door is open for more than 3 minutes.
The light goes out and the beeping stops when you close the door.
Jun 01, 2008 | GE PSS26MGS Side by Side Refrigerator
Door alarm
It depends on the model you have.  Look on the door panel and look for the control button that shuts off the alarm.  Press and hold the button 5 to 10 seconds and that should shut it off.  If you don't have that feature, then there's nothing to disable the alarm.
May 04, 2008 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
