Hdmi auto switch 3T01 does not switch automaticaly,help.
Mitsubishi WD-60C9 changing inputs on its own whats the cause of that?
HDMI auto is ON. Go to menu settings and turn OFF auto HDMI. That will stop the auto switching. Regards.
Aug 18, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
My sat box is connected to hdmi tv with hdmi cable and scart lead, but when i switch on in morning will not go to tv
You don't need the scart if you're using HDMI. However, the TV will not auto-switch with an HDMI connection.
If your TV does not switch on remembering its previous settings, you'll need to reselect HDMI each day.
Feb 27, 2014 | Televison & Video
Have just been given the Toshiba Hard Drive PX1396U-3T01, number 2978109s. No install instructions, or paperwork. He is now overseas. How do I install the HD, or get a driver?
Your Toshiba PX1396U-3T01 external HDD is USB-attached, so you'll need to acquire a
standard USB cable to accomplish the physical layer attachment. USB cables do not have
the same connector at each end - the system (computer) end has a USB "A" connector (flat-shaped), and the device end (HDD) has a USB "B" connector (square-ish shaped).
There is no software (driver) needed for this external HDD - support for USB-attached external
drives (either HDD or flash drives) is built into WinXP, WinVista and Win7.
IF your version of MSwindows doesn't want to recognize the Toshiba when you plug it in, try
START > Run > then type in "diskmgmt.msc"
then select the command "Rescan disks."
If you're running Mac OS or Linux, repost including your OS (operating system) info.
Aug 15, 2011 | Computers & Internet
I switched to an HDMI cable and do not get any sound when playing a game
Go to audio options, HDMI then auto-detect (or whatever it's called). Hope this helps
Jun 20, 2011 | Sony Playstation 3 (PS3) Console
I have got a problem with my two window of front of my car. i c,ant open & close automaticaly
the window switch assy has gone bad local auto parts should be able to get the switch for you they just pop into the door handle assy
Mar 03, 2011 | 2001 Nissan Maxima
When i plug in the hdmi cable in my ps3, my console automaticaly switches off. Is this a technical problem or maybe its because of my console settings?
there is no true HDMI cable for the Wii but a "Component" cable which is as near to HDMI as possible. The cable has 5 plugs on it (make sure your TV has the same 5 plugs). They are available off of ebay
better u download repair guide
click here to download repair guide
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
I have jus brought a acer aspire m5100 it has an hdmi output but i dnt know how to activate it can u help thanks
I have just spoken with Acer Support, and where M5100's have dedicated graphics cards, this disables the onboard graphics including the HDMI.
The onl way to eabl the HDMI is to remove the dedicated graphics card, and revert to shared graphics which will enable HDMI. The problem with this, according to the support technician, is that it will slow the computer down considerably.
Why the hell do Acer do this? They must know this is an issue in the first place; absolute idiots.
May 23, 2008 | Acer Aspire M5100 AM5100-U5313A AMD...
My ps3 doesn't starts automaticaly any games , cds or dvds
go to settings and then system setting and the second last one put it on auto and it will help you
Apr 22, 2008 | Sony Playstation 3 (PS3) Console
Hdmi
The HDMI lead only carries the video and audio from the HTS6510/05 to the TV.
The scart carries audio and video both ways.
Re-connect the scart lead and all will be ok.
N.B. When the HTS6510 is switched on, the TV will auto-switch to the scart input. You will then need to switch the TV to HDMI to get the benefit from the DVD upscaling.
Feb 02, 2008 | Philips HTS-6500/37 System
Computers & Internet Logo
262 people viewed this question
David Payne
David Payne
