Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
INSTALL.LOG ??
Hello...Starting a few weeks ago, I started getting pop-up windows saying ; '' INSTALL.LOG could not open file '' It usally happens when I try to open a file, any file, and when I try to uninstall a file and sometimes when I open my mail. What is this? Its really becoming a big problem. I tryed 3 different restore points and it did not help. Also, since this started happening, my log-on and log-off is extremely slow. It takes over 5 min. to log on or off and I have DSL. I contacted them and nothing is wrong on there end. Can you help me? I have a hp pavilion dv2000 notebook, not a dv2000t, but your list dosn't have this model listed. Thanks, Nancy
  • 10,594 Answers
Download and install Ccleaner free software to clean Windows registry and get ride of this install.log file.
Posted on Jan 25, 2009
    Brigadier General:
  • 8,619 Answers
Hi
In case you have installed a new program uninstall that program and install it again . Also you can go to Start Menu>programs>Accessories>System Tools >system restore .
Note : Any new data saved can be lost
This will restore the system to previous settings and will work for sure .
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jan 26, 2009
    It has occured because the last time you uninstalled a program/software it wasn't uninstalled properly thats why you are receiving this error and you need to delete the files by following this procedure :
    1. Open the directory where the program is installed. (Eg. For System Mechanic 5, By default, it is C:\Program Files\iolo\System Mechanic 5, if you have installed XP on C:\)
    2. You will see a file named "Install.log" in there.
    3. Move (cut and paste somewhere else) the "install.log" to say desktop.
    4. Now, double click the uninstaller (uninstall.exe or unwise.exe)
    5. It will ask you to open the installation log. Locate to the "install.log" file on your desktop.
    6. Now, uninstall will work fine and you can uninstall the program.
    Thanks
    Rylee
  • 15,935 Answers
There are 2 reasons why you may see the "Could not open INSTALL.LOG file" error message when trying to uninstall the program:
1) Usually this problem arises when file named "install.log" is missing from program folder. This file contains information about what files were copied during installation and is required to uninstall the program automatically using "Add/Remove program" applet. The "install.log" file may get deleted by some "eager" disk cleanup software that delete all files having .log extension. If you open your program installation folder and see no "install.log" file there, then you can't automatically uninstall the program. Instead, just delete the program folder and it's group under Start | Programs. None of our major program install files outside program folder.
2) If the "install.log" file is in your program folder, then probably there is something wong with uninstall information in the registry. On that case just double-click on the "uninstall.exe" file that is on the same folder and uninstallation screen should appear. If running uninstall.exe displays the same "Could not open INSTALL.LOG file" error message, then you probably have older uninstall program and need to drag "install.log" over "uninstall.exe" with the mouse and release mouse button. Then uninstall.exe will be started and install.log filename is passed on command line as a parameter.
Here is how you do it without having to manually remove all the files and registry entry.
  • Navigate to program’s installation folder
  • Cut or move the INSTALL.LOG to somewhere else. eg: desktop or my documents. Reminder: Move the file, not copy.
  • Run the uninstaller and it will ask you to locate the INSTALL.LOG file.
  • Select the file you move earlier and voila the program uninstalled!
Thank you for using FixYa = A FixYa rating is appreciated!!
  • blueextc3221
    blueextc3221 Jan 25, 2009
    A recently deleted program which wasn't un-installed successfully running in the background could be the cause of your pop-ups as well.
    START > RUN > and type "msconfig" (less the quotes).
    Click OK
    Then click the startup tab.
    Everything with a checkmark is slated to run when windows starts.
    De-select everything (except your antivirus program) and re-boot your computer.
    Windows Defender (free d/l from microsoft home), is also a good program for removing startup programs.
    Keep us posted!!
  • 10,515 Answers
Its due to registry change....
  U need to optimize registry.....
There are many softwares availble.....To scan this,...u can use the below mentioned software :)
http://www.pcfixreview.com/uninstall/cannot-open-install-log-file/
 And there are errors u can go to
http://www.download.com
 to download certain registry mechanic softwares...
Hope it wld slve ur issue..
ba bye.
  • 40 Answers
This sounds like a program in your startup is having difficulty finding a file. Does the error message give any further details?
Hey can you help here please i've downloaded a video games and install it. But everytime i click for starting or opening a game...something pop up saying Missing required file ,for example " QtWebKit
Use torrents to download the game you will get a cracked one with all the files. . Search on Google. . Torrent for . . Download the torrent and open ir in a torrent client like uTorrent etc
Nov 07, 2013 | Video Game Consoles & Games
Help me how to find my old password .
The experience forgot admin windows password happened to me few days ago. And I searched in the Internet to find the solution. Then I found a windows password reset tool called Windows Password Reset have a good evaluation.
I tried it as the steps:
Step1:Download and install Windows Password Reset from http://www.windowspasswordreset.net
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in my newly created CD and remove my Windows Password.
It really great help to me reset windows admin password.
Hope it help you too.
Aug 19, 2011 | Musicxpc Pro S3 P4 3.2 PC Desktop
Hi, i am having a problem trying to remoove yohoo messenger from add and remove programs, i get a message.,.could not open install.log file. my computer is now starting to low down.. confussed, ...
1) select Start->Run
2) click Browse button
3) find unwise.exe in Yahoo! install folder (usually C:\Program Files\Yahoo!\Messenger\unwise.exe), click OK in 'Browse' window
4) after that you should see in Run window the following:
"C:\Program Files\Yahoo!\Messenger\unwise.exe"
5) edit this line, so it looks like:
"C:\Program Files\Yahoo!\Messenger\unwise.exe" install.log
(after "the path" put the space and type install.log)
6) click OK in Run window
That should uninstall yahoo messenger.
Mar 11, 2011 | Computers & Internet
I have a gateway notebook MX3560, and it started running slow a couple days ago. Yesterday, after initial startup and entering my password to get into windows, it is locked up, and just shows my...
few possible things could cause this..
corrupted/malicious file(s) will do this..
An Out Dated or Expired NORTON or McAfee will also sometimes cause this...
A windows update can cause this.. as it will sometimes install or replace drivers/updates that you don't need...
Oct 06, 2010 | Gateway MX3560 Notebook
ID error = 0
the issue is caused by a Microsoft Jet update. in c:\icwin310\backup directory you will find the files needed by icverify. Make a backup of the following files in c:\windows\system32 msjet35.dll
msjint35.dll
msjter35.dll
msrd2x35.dll
msxbse35.dll
msexcl35.dll
msltus35.dll
vbajet32.dll
vbar332.dll
Copy the files listed from the c:\icwin310\backup directory to c:\windows\system32 and your error should be no more.
May 28, 2010 | Ic Verify ICVERIFY 3.1
PC crashes when i switch user
reboot to safe mode using f8 right before the windows logo screen at boot comes on. after on this, run a virus and spyware removal program. i recommend www.superantispyware.com for this.
this problem is mostlikely due to a virus or spyware. If all else fails, put your windows xp cd in and when this loads, select install windows then let it detect installed windows. select "repair" as your option for a repair reinstall, this will fix damaged or mising windows files.
Feb 11, 2010 | Microsoft Windows XP Home Edition Service...
Problem starting the program
Hello, I give advise & support on using a computer. If you need basic computer skills and advise, I will help you. You can get support from me, via Msn live chat, if you purchase a $4 one hour online session. If you want to find out more, please send an email to shane213@live.com
Sep 18, 2009 | Simon & Schuster Writing Tutor with Typing...
Turn on emachine, and dos menu pops up saying windows could not start because the following flile is missing or corrupt: WINDOWSSYSTEM32CONFIGSYSTEM then under that it says, you can attempt to repair this...
Borrow an installation Cd of your OS. Configur your computer to boot from CD.
Boot from CD, Choose (R) repair option. The recovery Console appears. Enter the number (1, 2 or other) that corresponds to the partition the system detected. If you see only one installation then you enter 1. You will then be asked to log in as administrator by supplying the password you entered whwn you installed.
When the C:\> prompt appears type
COPY [your_file_name] [SPACE BAR] C:\WINDOWS\system32\ [your_file_name]
After that Press [CTRL][ALT][DEL] to restart.
It should copy the missing file and you will be able to reboot.
Hope it helps
Rate the solution if it solves your problem.
Sep 01, 2009 | E-Machines eMachines Desktop PC
INSTALL.LOG ??
Can you open task manager ? When this msg come dont terminate it. Open task manager and watch which process is holding that error. Kill this process. Try to erase another file. If it happen again, you are attacked by a great virus. There is one solution without installing OS again. Scan your HDD with another PC which have a recently updated virus scanner. Keep informing.
Jan 28, 2009 | HP Pavilion dv2000t Notebook
Lsass.exe Error insufficient rescources? Annoying help please.
This usually happens when your hard drive is getting full and Windows cannot increase the size of the swap file. Check your amount of free space on the system drive (usually c:).
Hope that helps :)
Dec 21, 2008 | Compaq Presario Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
