Question about Samsung Rugby 2 ( Rugby ii) A847 Two Tones, and Hard Case/Cover/Faceplate/Snap On/Housing/Protector
Where do I find pin 2 code using straight talk and Samsung Rugby II?
I am able to use phone and text but no web access. Trying to reset settings and recommended to go to phone-security-APN Control(turn on) but to do this I need Pin 2. Not sure where to find it.
Raysagem
  • 1017 Answers
SOURCE: samsung x820 need a pin to reset call timer
You can protect the phone against
unauthorised use with a phone
password.
The phone will require
the password on power-up.
1. In Idle mode, press <Menu>
and select Settings
Security Change
password
2. Enter the default password,
00000000, and press <OK>.
3. Enter a new 4- to 8-digit
password and press <OK>.
4. Enter the new password again
and press <OK>.
5. Select Phone lock.
6. Select Enable.
7. Enter the password and press
<OK>.
eight zeros is the default, if you've changed it, you'll need the unblocking key from your service provider. Or if you've still got the box the phone came in, you'll find the puk number on there.
Posted on Feb 24, 2008
  • 52 Answers
SOURCE: i need a pin number to reset my phone.
hi,
try this which is default.
00000000
rate me if this helps
Posted on Mar 26, 2009
SOURCE: Taco Lite phone lock
Forgot my password for my phone lock what do i do ?
Posted on Jan 16, 2010
  • 108 Answers
SOURCE: need pin code to Samsung WEP200 headset to connect to samsunphone
pin code:0000
or
try this website
website
http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
Posted on Jan 22, 2010
  • 6 Answers
SOURCE: samsung r560 master reset code?
the code is the last 4 digits in phone #
Posted on Mar 05, 2010
I reset my APN settings on Samsung Note II to Strait Talk info. & saved. Rebooted my device & I still have no cellular. When I put the same SIM Card in another phone, I have cellular connectivity.
My first question would be have you registered the Samsung Note II serial with Straight talk? Unlike a lot of the older SIM-based phones, you can't just hot-swap the SIM card into any phone and expect it to work. If you HAVE registered it then you may have gotten a corrupt firmware flash. Hard reset the phone(USUALLY power plus Vol+ simultaneously) then re-try to reset APN again.
Apr 25, 2017 | Samsung Cell Phones
How you I turn up the volume on the ear piece
On my Samsung phone, I just put the volume up while talking on the phone. Anytime, press the volume key, and if a visual appears on the screen, tap the gear to the right and it will open up options for different types of volumes.
The other way should be to go into your settings and choose sounds.
Sep 26, 2014 | Samsung Rugby 2 ( Rugby ii) A847 Two...
I want unlock code for my phone samsung rugby II
there are too many sites provide unlock code from 15 digit IMEI number of Mobile phone. Use *#06# to show IMEI Number
Aug 02, 2014 | Samsung Cell Phones
Straight Talk issue on iPhone, SMS is not working.
The person you are trying to text may not be available for this specific service, and you may have to use the built-in Messages application. But if this is not the case, you can delete Straight Talk, install it again from the App Store, and login to your account. If this does not solve your problem, you can wait for the developers of Straight Talk to release an update for the application.
Dec 05, 2013 | Apple iPhone Cell Phones
Where is the "do not disturb" setting on a Samsung Rugby?
This is related to the Push to Talk function:
PTT Settings
1. In Idle mode, press Menu -> PTT and press the Select soft
key or the key.
2. Select PTT Settings and press the Select soft key or the
key. Choose from the following options:
• My Availability: this option allows you to change your Availability
status. Use the Up or Down Navigation key, to highlight Do Not
Disturb or Available and press the Select soft key or the key.
You can find the manual here:
http://images.comparecellular.com/phones/1362/samsung-rugby-ii-user-guide.pdf
Oct 21, 2013 | Samsung Rugby SGH-a837 Cell Phone
How to unlock
You can get the Unlock code from the site Simpleunlocking.com/supported-phones/rs16wp7/ and get free unlocking instructions at Mobileunlockguide.com/samsung-sgh-a847-rugby-ii and unlock it easily.
Jul 05, 2012 | Samsung Rugby 2 ( Rugby ii) A847 Two...
UNLOCK CODE SAMSUNG RUGBY 2
The first solution for sure will get your phone in 'phone freeze' mode I would highly recommend against that.
To obtain unfreeze + unlock code you can NOT order unlock codes via Provider service. They never deliver unfreeze code.
You can try by cable or just by region unlock (factory unlock codes service). Eg. www.unlocksamsungonline.com/unlocksamsung/a836
Jun 17, 2012 | Samsung SGH-A877 Impression Cell Phone
How do i down load a free manual for samsung rugby 2
Hello Sir just click on this link below and the user manual for samsung rugby 2 will open
http://images.wirelessdealer.ca/images/phones/userguide2628.pdf
Thanks for using fixya :)
Aug 06, 2011 | Samsung Rugby 2 ( Rugby ii) A847 Two...
Straight Talk Phone- cannot send or recieve messages. Called customer service they did master reset & restore by telling me code. lost all my phone numbers & my photos, still can make calls Just My...
Straight talk mms not working - Complete Troubleshooting Guide Straight talk mms not working - Complete Troubleshooting Guide. There are many folks out there that are having trouble with their Straight Talk MMS Settings, mainly not able to send or receive MMS on their Straight talk phone. This troubleshooting Guide is aimed at those guys who have already setup their Straight talk MMS Settings and are still not able to send or receive MMS on Android, if you are having this issue, please continue Reading, otherwise if you are looking into how to setup the MMS Settings for your phone, you should read THIS.
A few things can cause the Straight Talk MMS not working issue, these Straight Talk MMS problems seems to be very common, especially when people switch from another operator or recently changing to an LTE phone. The most common reason causing the Straight Talk MMS not to work are related to wrong setup on the MMS Settings, either having the wrong configuration or missing the correct MMS Proxy or Port. Let's get it done!
Straight talk MMS not working Step 1 - Verifying the MMS Settings
Please verify that your phone actually have the proper Straight talk APN or MMS settings in Place.
Please go to Settings > Wireless Connections > More > Mobile Networks > Access Point Names and verify that your values match these ones:
APN: wap.tracfone
Proxy: 216.155.165.40
Port: 8080
MMSC: http://mms.tracfone
MMS Proxy: 215.155.165.40
MMS Port: 8080
MCC: 310
MNC: 410
Save the settings, restart the Phone and TEST. If the above settings don't work for you, please try changing to these values:
APN: att.mvno
Port: 80
MMSC: http://mmsc.cingular.com
MMS Proxy: 66.209.11.33
MMS Port: 80
MCC: 310
MNC: 410
Save and Try again.
Straight talk MMS not working Step 2 - Verify your SIM
If you recently changed your Phone and you are using and old version of the SIM cards, sometimes this might be the problem. This is more relevant on the LTE Phones, and if you just recently ported your number from another operator, it might take a few days for it to replicate the settings over, in this case, just wait a little bit.
Straight talk MMS not working Step 3 - Install an MMS App
If the above two steps doesn't solve the issue and you are still not able to send, receive or Download MMS on your Straight Talk Phone, you can try downloading the GO SMS Pro APP, which seems to solve the issue for many people having this problem. This app also gives you additional features such as auto-reply, 800+ emotions and it's completely Free.
Nov 29, 2017 | Cell Phones
WHO CAN I CALL TONIGHT TO FIND OUT PUK PIN NUMBER SAMSUNG TRACFONE
If your PIN code is blocked, just enter your SIMs PUK code to unblock it. The PUK code can be found in the PIN slip that came with your SIM pack.
For lost PIN slip, you can:
1. Go to Web Connect at www.smart.com.ph/buddy/connect (for Buddy) or www.smart.com.ph/talkntext/connect (for Talk N Text).
2. Login to Web Connect using your Smart cellphone number and password. If you are not a member yet, select: REGISTER and sign up using your Smart cellphone number.
3. Select PUK Release to unblock your SIM.
Feb 15, 2010 | Cell Phones
Samsung Rugby 2 ( Rugby ii) A847 Two Tones, and Hard Case/Cover/Faceplate/Snap On/Housing/Protector Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
