Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Arctia no ice or water from door panel
First it was crushed ice only even with ice button pushed, but the water worked. Now there is no ice dispensed at all and no water either. The ice in the hopper is not filling anymore either.
I checked the back of the unit and at the water solenoid there are two plugs with two wire each. Disconnected both and checked for voltage with paddle depressed on the front panel, there is no power at either plug.
The small green light is on the panel and moves to each button when pushed, and when you depress the paddle you hear a small whir sound and the green light goes out while the button held in.
This GE MD #PSS26SGRE SS Ser # DL411622
Rain forest swing how do I take it apart
Posted on Jan 26, 2009
GE ice maker crushed ice selector does not work. It does work for cubes and water. Pushing the door button when cubes are selected causes the assembly in the back of freezer that moves a rod to open the...
Crushed ice makers have a tendency to freeze up the mechanism. So you might want to deinstall your ice maker and let it defrost for a day or two.
That would be where I started, but if that didn't fix the problem I would move on to the electronics/
May 06, 2012 | Refrigerators
Have ice but no water. Changed filter and can hear water filling filter. Front control panel operations intermittent at best. Light in dispenser not working.
what is the model number?also try pushing crushed ice or cubes,just worked on a g.e. and the control panel on the door was bad,it kept beeping and if you pressed crushed ice the water would work,had to change out the board on the door,send model number so i can look it up for you,if you can hear the water fillling up in the filter it could be the board or a frozen water tank line,remove the bottom draws and see if you can see the water tank,with a hair dryer heat up the line where it connects to the tank if your model has a tank,send model number
Sep 26, 2010 | GE Refrigerators
PSS23MSTC GE PROFILE WATER WORKS, ICE CRUSHED ICE INDICATOR LIGHT DIMS NO ICE IDEAS?
clean built up ice in the door where ice comes out.....make sure the metal bar is down. its located inside the tray where the stored ice is.
Nov 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker is not despensing ice, but water works. It is a GE Monogram refridg. Water works, but when you change to ice, nothing happens. when it was acting up, all it would do is dispense crushed ice,...
Could you look on the bottom frame of your GE Monogram around the door frame and behind the fresh food section door seal for the model number? The problem most likely is in that control panel that you use to switch from crushed to cubes. Let me know, Sea Breeze
Jul 22, 2009 | Refrigerators
Ice that comes from the door is always crushed
empty out all of your ice than wait for it to fill up a new tray and than it should be cubed if it doesnt change you might end up sticking with it because you will need to change the control panel behind the buttons your pressing
Jun 08, 2009 | GE Refrigerators
Water, ice and crushed ice dispenser doesn't work properly
you need to replace the board in the dispenser front housing on the front of the freezer door / larry
Mar 16, 2009 | Refrigerators
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge pss26sgrc ss ice/water dispenser
Take the outer frame off the dispenser area with a plastic putty knife. Start at the bottom and gently pry off, trying not to snap off plastic tabs that extend into door. Most likely you will have to replace the "interface" (part # WR55X10415) It is the small board where you select water / crushed ice / cubed ice. Relatively easy to replace. good luck.
If this helps, please rate response. Thanks.
Aug 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
133 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
