Question about Emerson MS3105 CD Shelf System
How to get the aux cable to work on a emerson cd player
Does using an ipod/AUX adapter through the CD changer input stop a real CD from working?
you have to change it from the Aux setting to CD when you want to play cd, some cd players switch to aux. automatically when you plug inthe aux. cable. and may have to be unplugged when playing cd.
Nov 28, 2014 | Car Audio & Video
Ford 6000 cd aux not working
I had the same problem. Solution is quite simple. Just remove positive cable from automobile battery terminal for about one minute, connect it back and AUX works again.
Jan 05, 2013 | Cars & Trucks
Try to play my MP3 through my Emerson Radio/CD system. When I push AUX it shows LINE on it and this is prevent me to listen to my MP3. Please help me..
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
May 23, 2011 | Emerson Audio Players & Recorders
I want to connect my tv to my stereo for sound but it is not working in aux mode can this be done
Your TV must have a sound output, preferable an RCA type output jacks, these are connected to aux or line inputs of your audio amplifier, in some TV sets, you must deactivate speakers at menu to have audio at these outputs, please check your TV user guide for more details.
Feb 20, 2011 | Emerson MS3100 3-Disc CD Changer
Where can i get a cable to connect my Emerson EMP313-4 to a speaker system?
you could use an AUX cable but only if the speaker can use AUX. what speaker are you trying to connect to?
Nov 02, 2009 | Audio Players & Recorders
How do i hook up a ipod to the cd player
Go here:
http://www.crutchfield.com/S-j3EX2WZGpxL/p_113MP232/Kenwood-KDC-MP232.html?tab=features_and_specs
You can download the manual and specifications.
Oct 06, 2009 | Kenwood KDC-MP232 CD Player
Aux problem
You have to go into the standby menu and turn aux on. Go to standby, push menu button and scroll down to aux and turn on
Aug 05, 2009 | Kenwood KDC-MP235 CD Player
CONNECTING AN AUX CABLE TO PLAYER
Unfortunately, you can't. I have the same deck, and it has no aux in capability. The S5050 is simply a CD player, not even an MP3 player.
Mar 25, 2009 | JVC KD-S5050 CD Player
Comcast DVR 3 Remote doesn't work with TV
You may have to use a separate remote control for your TV.
Jun 05, 2017 | Emerson Televison & Video
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
Emerson MS3105 CD Shelf System Logo
46 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
