Question about Technics SL-BD22 Turntable
My technics sl-bd22 platter stop running what I do:
5 Suggested Answers
SOURCE: How to remove a Technics sl- db20 platter
pull
Posted on Jul 28, 2008
  • 476 Answers
SOURCE: The platter on my Technics SL 1200MK2 stopped spinning
If you remove the rubber pad from the top of the platter then you should be able to lift the platter off the servo drives' center shaft,
from memory the unit is not attached just held on by gravity,if the servo magnet is gone the take it in for a service and pay the man for his time,
My first problem on my 1200s was a pitch control issue and easy to fix,with a little cash,never use second hand parts unless you know what you are doing because when they fail on you while playing to a packed dance floor then youll get more of a supprise than you barginned for,
Misterdj
Posted on May 03, 2010
  • 256 Answers
SOURCE: How do I remove the platter on a sl-bd22 Technics
You will have to lift off the cloth on the platter section to expose two rather large holes in the plattr. Insert your thumb and forefinger, and pull up.
Posted on Jul 13, 2010
SOURCE: Technics SL-BD22 ground wire does not reduce hum. Any solutions?
I have found out that the female phono plugs on the turntable are sensative and have to have a solid connection and often adjusted from time to time to eliminate the 60 cycle hum.
Posted on Nov 04, 2010
Tehnics sl-bd22 noisy motor what to do?
If the bearing is worn to the point of a rattle and a small amount of silicone oil won't stop it, then it should be replaced or the motor replaced. These bearings are normally lifetime impregnated with lubricants and can sometimes dry out with use and somewhat seize up causing what may sound like a rattle. If the motor shaft has worn down enough at the bearing point, then a rebuild or replacement is in order.
Dec 01, 2013 | Technics SL-BD22 Turntable
After 14 years my Technics SL-BD22 Turntable has a disfunction The electric motor turns slow.
Your turntable is probably belt driven so most likely motor is turning okay but belt is slipping.
They are easy to change, first just lift rubber mat on platter and you should be able to see the belt through a access hole in the platter.
Feb 28, 2011 | Technics SL-BD22 Turntable
I had not used my turntable for about five years due to no needle. Found a needle and played two LPs, then on the third one, it just did not move or work at all. It lit up but just acted like it had no...
The low grinding noise could be the motor spinning with "no load" i.e the belt has snapped or fallen off due to being perished.
Lift the platter to refit the belt and or replace it if required.
Jul 23, 2010 | Technics SL-BD22 Turntable
How do I remove the platter on a sl-bd22 Technics turntable?
Jul 12, 2010 | Technics SL-BD22 Turntable
Tecnics turntable Model SL-L26
Terry, Remove the rubber mat from top of platter. This will expose two slots in the aluminum platter. Lift aluminum platter straight up and off. On the underneath side of platter is a surface that the belt will fit on, place the belt there(approximately half the diameter of the platter) With the belt mounted on platter, reinstall platter to turntable. Slowly rotate platter until you can see the drive motor pulley, stop. Carefully reach down and pull belt over drive motor pulley (make sure not to twist belt) Rotate platter to ensure smooth operation and belt tracking. VOLA! Reinstall rubber mat and vynil on!!
Jun 11, 2009 | Technics SL-BD22 Turntable
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
How to replace drive belt for model.# SL-BD22 ?
Nope, very simple...
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Feb 28, 2009 | Technics SL-BD22 Turntable
Turntable grinds to a halt.
The Technics SL-BD22 is a belt driven turntable. It is most likely possible that the belt wore off, wore down, or could have spun off. The platter should have 2 holes in it. One of them should alow you to see, and replace the belt. YOu can lift the platter off the turntable via those two holes. MAKE SURE IT IS TURNED OFF AND UNPLUGGED......
You can find a replacement @
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES-Drive_Belts/c271_272_278_398/index.html
And the part should come with instructions. Those guys are very thorough.
Keep me posted.
Nov 05, 2007 | Technics SL-BD22 Turntable
Technics SL-BD22 Turntable Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
