Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Changing the Lamp
I have a Sony Wega LCD rear projection tv Model # KDF-60WF655. I am trying to replace the lamp... Which panel do I remove to get to it.
    Scholar:
  • 150 Answers
Hi, they are all a little different but 95% of all Sony`s require you to remove the plastic panel just below the bottom of the screen, your owners manual has the procedure, if you don`t have it you should download it from the sony site. Basically there are either velcro or long plastic plugs that hold the plastic panel into the set, be sure to check for several screws that sometimes need to be removed just behind the bottom front cover, hard to explain over the internet, best to get the owners manual and follow the correct procedure for your model, hope this helps, video-tek
Posted on Feb 04, 2009
Grand Wega KDF-60WF655 ...The picture has recently gotten dark....with cable, dvd's, and vhs tapes...
The tv projection lamp live is ending.Change the tv projection lamp,will solved this problems.
Aug 12, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony grand wega kdf 60wf655 will not start up. red light blinks three times. lamp replaced a year ago.
If the POWER/STANDBY indicator flashes three times, the lamp cover may not be attached securely. Review the lamp-changing instructions in your owner's manual, and make sure that the lamp cover is securely attached.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Replacing lamp
Lamp replacement procedure is written in user manual,check page-17
Click Sony Support to download free copy of user manual of KDF-60WF655 if required.
There are two thumb screws at lower corners if you see tv from rear, remove these screws and take out lower front panel, in center of that space, you will see lamp cover, remove it and unscrew old lamp, pull it out and put new lamp then put things back in reveres order.
Required lamp of KDF-60WF655 is available in Sony Accessories Store for $200 under part number XL-2200
Hope these info will help you.
Thanks.
May 13, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
It overheats and pops the Xl-2100u lamp?
by pops? do you mean it explode? how many lamps? it could be the fan that supposed to be ventilating the lamp or it could be the the ballast, why the ballast because the ballast regulates the voltage in order the keep the lamp on, for ignition it sends around 15,000 volts after that it regulates the votage to a small amount of voltage around 5,000 so it could be sending the big amount of voltage all the time never regulates that or it could be regulating and then sending another big amount of voltage over and over until the lamp doesnt handle those changes.
Apr 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
What can make the TV to stay on for less than a minute and then turn off to do the same over and over?
Weak lamp can cause that symptoms, replace lamp in TV to fix this problem.
Lamp replacement in Sony KDF-60WF655 is easy and procedure is mentioned in user manual.
Thanks.
Oct 12, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a Sony kdf-60wf655 60 in.rear with dark images and por colors
Lamp is cause of dark image in your tv. Lamp indicator will flash when lamp will be dead.
Nov 07, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
112 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
